Old 09-21-2004, 10:17 AM   #1 (permalink)
Aftermarket Coil to Distributor Wire
The stock coil is a socket, the aftermarket coil (Crane) is a plug (tower). Does the stock coil to distributor wire fit? If not, where can I find this wire/connectors?
One option i found was to use a Blaster-2 coil or a Crane PS-60 coil with the right head.
nite-stalker is offline   Reply With Quote
Old 09-21-2004, 11:21 AM   #2 (permalink)
RepnE.N.Y.Brklyn
just cut and solder the wires together! i have the msd sci and the msd blaster coil. i cut the socket that led iinto the stock coil and soldered the 2 wires to the positive and negative wires on the msd sci. thats the easiest way to go.
'91 se-r,
BB sr20det, T25 turbo, Jwt ecu, jun flywheel, carbon/kevlar springload 6 puck clutch, blitz b.o.v, apexi avc-r, Apexi Turbo timer, Msd sci, Msd blast coil, Vrs 2.5 turbo back exhaust, Apexi n1 turbo muffler, Nismo shift knob, Nismo steering wheel, B&M short shift, autometer gauges, ground control/kyb suspension
http://img.photobucket.com/albums/v3...nismowheel.jpg
brklyn is offline   Reply With Quote
Old 09-21-2004, 12:30 PM   #3 (permalink)
we are talking about the thick high voltage wire here.
Old 09-21-2004, 12:37 PM   #4 (permalink)
Technician @ Toyota
scortch99th's Avatar
I have the crane coil. You have to cut and solder the stock two wires on the harness of the crane coil, then you have to buy a replacement cables thats long enough to run from the stock cpa to the coil's position. Real easy any auto parts store should have one.
Old 10-11-2004, 06:43 PM   #5 (permalink)
for future reference, those that got the 10mm wires, magnecor can fab up a 10mm wire from a HEI(tower)-type coil to our stock dist cap socket. less than $20. with this you can use blaster 3, blaster ss, crane coils, etc.
