Old 09-21-2004, 06:24 PM   #1 (permalink)
"shift_happens"
Trader Rating: -1 (0%)
Help/Idle Problem: AAC valve, question.
Okay my car was Idleing high at about 1500-1700 rpm. I started wiggling some wires/ connectors on/ around the AAC valve and my Idle dropped back down to around 1000 RPM. When I disconnected the AAC valve electrical connector, the
Idle didnt drop like its suppose to? Bad AAC valve? The Connector that seemed to make the biggest differance in the Idle when I wiggled it was a small black clip that just slides on a little metal piece, located a little above and to the right of the AAC valve connetor.
91 sentra se-r,sr20de, p&p head, balanced internals, 2.5" catback, unorthodox pulley set, fidanza flywheel, short throw, strut tower brace, HS CAI, aftermarket mounts, nx2000 brake upgrade, weaponR header, ebay steering wheel, minor weight reduction...
james_se-r is offline   Reply With Quote
Old 09-21-2004, 06:31 PM   #2 (permalink)
"shift_happens"
The little black clip actually plugs into something on the cooling lines, why would that affect my idle? maybe a short in my wires?
Old 09-21-2004, 06:41 PM   #3 (permalink)
Nos Slut
james that is the air regulator. Its what gives you that higher idle till your car warms up. It could be bad??
95 200sx SER
PS Header w/ 2.5" Collecter| 3" Intake w/ POP| 2.5" Exhaust w/ Cherry Bomb Pro muffler| ES Bushings| NX2000 Sway Bar| 91 Intake Cam| G20 Ecu
96 Sentra 1.6(B13)
Lightend stock flywheel| ACT HD PP w/stock disc| UR Crank+PS Pulley| 3" Intake w/ K&N Cone| XS Power Header| ES Bushings| ST Sway Bars| 2" Exhaust w/ Magnaflow Muffler| 60mm TB| Intrax Springs| 50hp Shot NOS
HaulinSentra is offline   Reply With Quote
Old 09-21-2004, 06:59 PM   #4 (permalink)
My Ass, your face
vladha's Avatar
If nothing happens when you disconnect it, then your AAC valve is bad. Bad AAC, you can't set your base idle and you can't set your timing correctly... ask me how I know.
Peace,
Mark
vladha is offline   Reply With Quote
