Old 09-22-2004, 11:53 PM   #1 (permalink)
technics professional
Avshi750's Avatar
Trader Rating: 35 (100%)
can i check torque# of Haynes + PICS of sway install
my old 'n ugly Haynes manual has the torque#'s for these bolts...
for the bushings... 65 - 80. sound right?
ok as for the install pics...
PROJECT- GXE rear sway removal and SE-R rear sway install...
here is the begining of the story...
http://www.sr20forum.com/sr20de-technical-corner/90750-cars-up-jacks-need-some-help.html
hehe... so i finally got 'em loose.
here is the skinny ass GXE rear sway next to the larger rear SE-R sway. (snicker snicker)
^^ here you can also see the two champs that nocked those f-ing nuts off. a new 18" flex bar, 10" didnt cut it, and a can of PB blaster. thanks to those who helped with that... i even considered renting an impact wrench & compreser.
a close-up of the two.
Avshi750 is offline   Reply With Quote
Old 09-23-2004, 12:35 AM   #2 (permalink)
fartin dust
On the u shaped brackets with the bushings the FSM says 23-31 ft-lb. On the link to the strut is 12-16 ft-lb.
I used to be a noob but now I'm just a dumbass
www.m4exhaust.com
james vick is offline   Reply With Quote
Old 09-23-2004, 12:59 AM   #3 (permalink)
Avshi750's Avatar
damn... i'm way off. i need one of those FSMs, better info from the source.
Old 09-23-2004, 12:05 PM   #4 (permalink)
bla bla bla
torque settings? just get em' tight and not worry about it
2003 VW gti 1.8t
72 Datsun 510-sold
Old 09-23-2004, 12:08 PM   #5 (permalink)
eric96ser's Avatar
Trader Rating: 16 (100%)
More than likey that 65 - 80 is inch/lbs. I cracked the valve cover on my old car by not seeing the inch/lbs part. I agree with Brian, just tighten them good.
1991 Sentra SE-R
The community is here.
Old 09-23-2004, 12:43 PM   #6 (permalink)
Avshi750's Avatar
well for a good example... the link bushings that are on either side of the strut mount... i can just keep squishing these w/o any problem. guess i'll just back 'em off a little, check my torque and see if i'm happy.
thanks everyone
Old 09-23-2004, 01:47 PM   #7 (permalink)
fartin dust
thanks everyone
Just squish them till there the same as the washer on there and your good to go.
