OK I searched my balls off cant find a post with this problem.....
When the car is cold it will go all the way to redline no problem. after its warm, sometimes at 4, some times at 5 and sometimes in between, it feels like i have a rev limiter. If i stay in it, it will pass that RPM range and go to redline as normal. Its driving me nuts. I checked all connections, vacuum lines, intake hoses, reset the ECU, have no check engine light. Plugs, wires, cap, rotor are new. Exhaust is new from the head to the muffler.
TIA
Ray
