Old 09-24-2004, 10:36 AM   #1 (permalink)
MYSPACE.COM/STREETARMOUR
Hit with multiple problems at once!!!!
OK, this is what is going on with my B13.
1st of all my AC bearing went and now I hear a crunching noise when I drive without the AC engaged. When it is on I have complete silence, but right now Phoenix has the bomb @$$ weather right now so no need for the AC
2nd I am driving to work and when I turn I hear a Clack clak clak noise from my passenger side tire. My axle is half way going out on me
3rd I still haven't got around to changing the driver side wheel bearing so the annoying grinding noise is still there whenever I am going faster than 20 mph
4th I started my car in the morning as I do everyday when I go to work and the car kind of hesitated to start I didn't think anything of it. I was going to Burger King to get a $0.99 Whopper When the car didn't even kick over. My friend helped me push start it and off I went. I first thought the Battery was dead or maybe the alternator took a crap on me. But no it had to be the starter!
5th, here is the kicker! After I rested at home after awhile I decide to inspect the B13 bumper to bumper. After I got done being a grease monkey, I let the car down from being up on jacks. I wanted to assess the cars handling and see if I missed anything. I am in first gear at 3000 RPM's and I let off and the Nismo front motor mount insert rubber piece shifts or something causing the motor to jerk forward hard as hell and then my shifter slams/power shifts itself into second (or so I thought) and the NOTHING! I cannot shift gears or anything I am stuck in second gear but it is acting like neutral. Here is what happened, the rear motor mount support piece that bolts to the tranny-to the rear motor mount- to the block had only one of three fuken bolt holding it on!!! So the jerking motion caused too much stress and busted the ONE bolt holding it together. So I have to drill and retap the tranny holes and hope for it to work. The Jack@$$ that changed my clutch 1 1/2 ago didn't even put the other 2 bolts in. I am amazed that the bolt lasted this long.
This is gonna be a long weekend.....................
But the SR20 is UNHARMED, Hooray!!! (I gotta look at the bright side).
2nd Runner is offline   Reply With Quote
Old 09-24-2004, 10:57 AM   #2 (permalink)
RepnE.N.Y.Brklyn
!!!!Dam!!!!!
'91 se-r,
BB sr20det, T25 turbo, Jwt ecu, jun flywheel, carbon/kevlar springload 6 puck clutch, blitz b.o.v, apexi avc-r, Apexi Turbo timer, Msd sci, Msd blast coil, Vrs 2.5 turbo back exhaust, Apexi n1 turbo muffler, Nismo shift knob, Nismo steering wheel, B&M short shift, autometer gauges, ground control/kyb suspension
http://img.photobucket.com/albums/v3...nismowheel.jpg
brklyn is offline   Reply With Quote
Old 09-24-2004, 11:35 AM   #3 (permalink)
Off-Topic lurker..
After the whopper settles, take a trip to your local ABC store. LOL just kidding man...damn that sucks you had those problems all in a day! Knock out one problem at a time...that's all you can do, really. And drink ice cold beer while doing so.
silversx is offline   Reply With Quote
Old 09-24-2004, 11:40 AM   #4 (permalink)
Your dead Twinkie
Benito Malito's Avatar
Trader Rating: 32 (100%)
That sux dude. My B12 had tranny mount bolts that were totally stripped too, kinda pain in the ass. I had the mechanic re-enforce the dog-bones (it ahd 2) to stabilise it till i could have it re-tapped. Maybe just get a belt to elimenate the ac for now.
I have a long weekend ahead of me too. Waiting for UPS to show up with my clutch/brakes from courtesy. I still need to pick up shocks. Although compared to you my B13's woes seem rather pedestrian.
1992 SE-R 'Fasty' Mods and mods in boxes. Ready for more boost, or more vvl.
