Old 09-24-2004, 12:32 PM   #1 (permalink)
SR20 Geek
Big Idle Problem
Well I was on my way to fix my motors yesterday, when my Idel started screwign up. First it would rev up to 4000 RPM in neutral and when clutch was pushed in. That stopped after a while and my idle just bounced aroudn for a while. On the freeway, it woudl rev to 7k on the rpm and stay there. I would have to shut my car off every time I would stop. Then My break started to get harder to push in (felt like car was still off). Anyways, the way we fixed it, the little idle screw worked its way out. We screwed it back in but it wanted to come out again so we took the whole this off. Also it made the cruise control throttle body screw up and loose. Damn Nissans .
B14Boost is offline   Reply With Quote
Old 09-24-2004, 06:04 PM   #2 (permalink)
did you check to see if your throttle cable was getting pinched or caught u7p?
Sold
SOLD
c('o'c)
SR20ANONYMOUS
gtirb13 is offline   Reply With Quote
Old 09-24-2004, 06:26 PM   #3 (permalink)
No soup for you
Trader Rating: 30 (100%)
The throttle adjustment screw requires a jam nut.
John
B12 turbo madness
424 whp / 328 ft. lbs
2440 lbs. w/ a full tank
B14 VE Hotness
244 whp / 228 ft. lbs
