Old 11-24-2001, 03:27 PM   #1 (permalink)
Ben
www.motorists.org
Ben's Avatar
emergency brake funkiness
Today I go to let my emergency brake down and it won't go down all the way. After playing with it it finally went down all the way with a little force. Made a squeaky sound you could hear outside the car. Heard the rear brakes a little on the way out of my driveway too. Did my emergency brake cables spontaneously rust solid? It was sitting in the garage all night. They are fine now- made a couple trips today since.
99.5 Audi A4 Avant 2.8L quattro 5-speed
03 Honda Odyssey EX-L
Ben is offline   Reply With Quote
Old 11-24-2001, 04:01 PM   #2 (permalink)
Nick
Stuck on an island
hmm thats weird ? spray some of the joints/cable with lube, maybe just some dirt in making it stick ?
279 hp @ 17psi
Nx 2000 : It sticks to the road like bubble gum to hot asphalt
Nick is offline   Reply With Quote
Old 11-27-2001, 03:55 AM   #3 (permalink)
1BAD_NX
School Sucks!!
The E brake on my nx has gotten to the point where it doesn't disengage anymore(frozen caliper pistons??) so I just completely stopped using it. But the brake handle on mine goes down without a problem the only problem in my case is that the brakes don't release. Try spraying some WD40 on the rear calipers and hopefully that noise wouldn't come back.
I dont know too much about brakes so this is as deep as my knowledge goes
Good luck,
Nick
http://www.sr20de.org/images/images/...000/n24cut.jpg
1993 Nx2000 BB DET, PS short shifter, ACT HD s/s clutch, ST front and rear bars, and AGX/Eibach suspension.
1BAD_NX is offline   Reply With Quote
Old 12-01-2002, 11:56 PM   #4 (permalink)
exxd
retired
The rear right caliper locked up on me a few days ago, I took the wheel off and pushed on something the spring was connected to (sorry dont really remember) and it unlocked... maybe those are the parts sticking. There was a loss of tension on my e-brake handle when it happened.
Old 12-02-2002, 09:20 AM   #5 (permalink)
Bowlcut
pwnd
sounds like the cable froze. How cold has it been there Ben? I know on my samurai it froze a few times. Usualy did it below about 20 degrees it did it alot.
-Kevin
We are a community
Old 12-04-2002, 12:30 AM   #6 (permalink)
SENTRASER
Drive it like ya stole it
SENTRASER's Avatar
Trader Rating: 33 (100%)
Mine did the same thing Ben, it does it off and on. I dont personaly know what it is, I believe its something in the actual handbrake itself, and not the cable or the caliper. If it was the cable, the brakes would simply not disengage, and the handel would go down, and the cable wouldnt move, because its only acctually held on to the handel with a nut on the end of a cable that has a bolt on the end of it. Theres nothing on both sides of the bolt, just one one side. It bassiclly just pulls on the cable and depends on the springs on the calipers for the cable to release tension. Hope this helps, and if you dont understand, its late, and I'm going to bed...
~Ryan
1992 NX2000 Hardtop
1989 B12 AWD wagon
Originally Posted by chriscar
Old 12-04-2002, 12:36 AM   #7 (permalink)
nite-stalker
hmm, usually its the caliper or cables... but this time i would say its the ebrake handle itself... the release button is really a funky mechanism inside, not surprised if one in many decides to give up, too bad its happening to ben...
of course, make sure its not the ebrake pivot on the caliper thats seizing first... its usually that or the cable..dump a load of wd40 there...
nite-stalker is offline   Reply With Quote
Old 12-04-2002, 02:21 AM   #8 (permalink)
akes200ser
Shift_UK SR20
ok
Hey i have a question do yr rear brakes release *** i just got in my car and my rear brakes won;t let go my rar brakes won;t let go are these problems so can the same things that fix these tahnx
96 200sx Se-R "B14 Monster"
UK SR20DE red top, Hotshot CAI and Gen 5 header, Stillen strut bar, ACT Clutch, Optima Red Cap, B & M Short Shifter, Redline Fuilds, Kumho v712, K&N oil/air, Glow Gauges
93 Sentra Se-R "1SLO SER"
W11 DET, ACT Clutch, Strut Bar, GC Coilovers with AGX's, 3" DP and dynomax exhuast, Turbo XS RFL BOV, Optima Red Cap, Precision Front Mount
17" Rev Hard, auto meter ultra light (oil, boost, A/F)
APEXI SUPER AFC II - my DAILY NIGHTMARE
akes200ser is offline   Reply With Quote
