Old 10-29-2004, 11:40 PM   #1 (permalink)
Trader Rating: 81 (100%)
PLEASE HELP!!! Emission failure problem
I took the car through Virginia emission inspection and failed. the motor was recently rebuilt with new rings, rod and main bearings.. valve job etc... Something is terribly wrong as the (HC pm) hydrocarbon at the tailpipe at 15mph on the rollers had a limit of 119 and the car read 201. At 25 mph the limit was 115 and the car read 170. The (NO pm) ......, not sure what it is at 15 mph had a limit of 945 and the car read 4959 and at 25 mph had a limit of 855 but the car read 4839.... Does anyone know what the problem may be? Any help will be appreciated.. Thanks guys
TURBOSER1 is offline   Reply With Quote
Old 10-29-2004, 11:46 PM   #2 (permalink)
The motor is a stock usdm motor... Modifications include headers, intake and a thermal research exhaust system. All the emission stuff is on the car. The
Old 10-30-2004, 12:20 AM   #3 (permalink)
the spookman
Yeah im having the same problem except the only thing i have is an intake. My HC count was like 251 or some crazy sh*t like that. I hope its not my CatCo Hi-Flow Cat...
05 Legacy GT
93 NX2000 w/VE
(\__/)
(O.o )
Old 10-30-2004, 12:33 AM   #4 (permalink)
this is driving me crazy man..... BTW hows that throttle postion sensor doing?
Old 10-30-2004, 08:03 PM   #5 (permalink)
the spookman
well the plug works nicely however the sensor got fried...heh. I had to go back to my old sensor which still works thankfully.
Old 10-31-2004, 11:49 PM   #6 (permalink)
Well HC's usally indicate a misfire and NOx is controlled by your EGR.
Paul
1992 Sentra SE-R
1992 240SX HB
1993 Sentra SE-R (Sold)
1992 Sentra XE (Sold)
B13SentraXE is offline   Reply With Quote
Old 11-01-2004, 02:20 PM   #7 (permalink)
just workin'
when was the last time you did a tune up? how old is the cat? could you post all of the exhaust gas #'s from the test to give you a hand
DnS Performance
Imported Auto Center, INC
96 g20 auto, stock
totaled200ser is offline   Reply With Quote
Old 11-02-2004, 02:22 AM   #8 (permalink)
Sorry to hear that.... but glad you sorted out your troubles...
Old 11-02-2004, 02:24 AM   #9 (permalink)
I checked the egr pipe off to find out that it is blocked up.... I'm gonna clean and re-install it to the car... I cleaned the throttle body also...
Old 11-02-2004, 02:30 AM   #10 (permalink)
The plugs and oil were changed about 2k ago but thats about it... I have not had the car that long.... Its beel only 6 months i bought the car with the cat on it but it looks pretty rusted on the outside.... You think that may be my problem? I left the test results at work so i will post the numbers tomorrow.... Thanks in advance....
Old 11-03-2004, 09:19 PM   #11 (permalink)
broke, busted and rusted
if you have both High NOx and High HC's at the same time its usually the cat.
If you have just one or the other, the go search and destroy on some vacuum leaks. If you dont have any then play with the timing especially since you said that you just had that motor rebuilt.
i program my heart to beat break beats and hum basslines in exhalation - matter, verse, spirit
TELL THE TRUTH!
Fonque is offline   Reply With Quote
Old 11-05-2004, 12:27 AM   #12 (permalink)
the spookman
Hmm yeah Ive got some bad misfire. My timing is at 15*, replaced my sh*tty autolites with NGK Bk6re VPOWAH plugs , NGK wires, cap and rotor. Still the samn thing misfires.
Old 11-06-2004, 03:38 PM   #13 (permalink)
NX2000 so long........
If the ECU was reset lately (maybe with all the engine work?) it will need about 300 to 500 miles to "learn" all over again before it adjusts everything right for emissions.
nmartin is offline   Reply With Quote
Old 11-16-2004, 08:16 PM   #14 (permalink)
You were partially right... It turns out that the cat was not working like it should but the egr tube was also blocked.... I cleared the blockage and replaced the cat... It passed the emissions inspections.... Thanks
Old 11-16-2004, 08:18 PM   #15 (permalink)
Did not reset the ecu... Thanks for the help
Old 11-16-2004, 08:19 PM   #16 (permalink)
Thanks for all the help and info you guys took the time to post. I got the problem sorted out.....
