Old 10-30-2004, 07:00 AM   #1 (permalink)
FWD PWNAGE IS HERE!
'96 Sentra originally w/GA16 now has SR20 and radiator fans won't kick on :(
1996 Sentra 200sx originally powered by ga16
-converted to '98 sr20
-I believe the harness was swapped out to a '98 harness as well
-now swapping in jdm sr20
-radiator fans will not kick on at 212*(temp monitored via techtom)
-fuses are all good
-temp gauge in dash reads 1/4 up from cold even at 212*
-swapped the 2 temp sensors by the aicv on the intake manifold from the usdm engine to the jdm engine
Not sure what else needs to be checked in order to get this fixed or if anyone else has encountered this problem before. Any suggestions?
SR20 Inside is offline   Reply With Quote
Old 11-02-2004, 03:18 AM   #2 (permalink)
FWD PWNAGE IS HERE!
ttt...
Old 11-02-2004, 08:21 PM   #3 (permalink)
did you hotwire your fam tp see of ot works direct?
3BiP is offline   Reply With Quote
Old 11-02-2004, 11:48 PM   #4 (permalink)
sr20 addict
did you swap a high port???
White 93 SE-R
Mods:
JWT POP
JWT S3's
JWT PP & Disc
OBX Header
VRS 2.5 Cat-back
Eibach Springs on KYB AGX's
B&M SS
Hyperflex Kit
http://memimage.cardomain.net/member_img_a/574936_36_full.jpg[/img]
///M5 is offline   Reply With Quote
Old 11-03-2004, 04:11 AM   #5 (permalink)
FWD PWNAGE IS HERE!
Yes a switched was rigged up and the fans work just fine.
Old 11-03-2004, 04:12 AM   #6 (permalink)
FWD PWNAGE IS HERE!
It from from ga16->Lowport SR20->Highport SR20.
Old 11-03-2004, 03:46 PM   #7 (permalink)
sr20 addict
cause i know the high port tempsensor are different than the low port ones
Old 11-11-2004, 10:00 PM   #8 (permalink)
FWD PWNAGE IS HERE!
if i try to use the jdm plug which would be the high port one the connection is dfferent than the plug on the harness...
Old 11-11-2004, 10:38 PM   #9 (permalink)
Make sure the cooling system is bled correctly otherwise the fans wont turn on correctly from the temp sensor.
B13DET is offline   Reply With Quote
Old 11-11-2004, 10:45 PM   #10 (permalink)
FWD PWNAGE IS HERE!
I made sure there were no air bubbles if that is what you mean
