Old 10-31-2004, 07:55 PM   #1 (permalink)
Vibrate in front suspenion
I have a vibration on my front end on the highway when driving trying to find the problem it feels like it coming from the front... replaced the inner and outer tie- rods had the front end check nothing.. could the strut tower cause a vibrates at most speed.. thanx for any help...
Twomissanman is offline   Reply With Quote
Old 10-31-2004, 08:18 PM   #2 (permalink)
Do the non-believers Bad.
Did you check your rack and pinion? I think a strut would definately cause that as well.
Jerimiah ------
1999 G20 - The new twinkle in my eye.
jerimiah is offline   Reply With Quote
Old 11-01-2004, 12:41 PM   #3 (permalink)
I had a bad vibration and it was the wheel hub bearing. Just a thought.
'97 SE-R with BB T25 setup, G20 ECU, E-Manage, Starion FMIC, SPEC 6 puck stage 3 clutch, D2 coilovers, fully shaved doors including side molding, Royal Sapphire Pearl (Toyota Supra) paint, Halo headlights, Aerogear vented hood, 98 Sentra Grille, Vis Extreme front bumper, Andy's Autosport rear bumper, and Kenwood Excellon CD player (Formerly Raser-X's car)
http://www.uwm.edu/~elh3/Pictures/20...rbocharger.jpg
Tomcat5678 is offline   Reply With Quote
Old 11-02-2004, 05:16 PM   #4 (permalink)
After doing all of that and if no success try checking the rims. They could be bent.
da_linkwent is offline   Reply With Quote
Old 11-02-2004, 05:45 PM   #5 (permalink)
|-|33| @|\|[) +03
check tires for uneven wear
*way cool '93 se-r
SirTwenty is offline   Reply With Quote
Old 11-03-2004, 09:13 PM   #6 (permalink)
check tires, tires wearing good... It feels like something lose on the front end I feel the vibration in the floor .... check axxles andd motor mount all that seems fine can the shifter bushing cause this vibration...
Old 11-03-2004, 09:51 PM   #7 (permalink)
SR powered S13 coupe
McCoy's Avatar
Trader Rating: 74 (100%)
have you rotated tires from front to rear. If the shimmy goes away or feels like it is from the rear, then it might be a bent wheel or missing wheel weight... Also have you checked your axle nuts lately?
Old 11-04-2004, 04:57 PM   #8 (permalink)
found what the problem was it was my in axle inner joint ... thanx for the heelp guys...
Old 10-23-2006, 04:06 PM   #9 (permalink)
all sentras r slow!
So what was wrong with the inner joint, because im having similar problems?
black93classic is offline   Reply With Quote
