check the spark wires...to see if they give spark...im sure you have done that....if not that then turn the key to on...let fuel pump prime for a few seconds so it build up pressure, then turn on engine and let it crank over and over and see if that works...let it crank over alot of times....stop and try agian,....mines only start when cold...after wormed up it will take many tries for it to fire up...ohh and also hold your throttle so you are at full throttle....this is how i start my car now....
CUSTOM MADE!
for sale:
side exit exhaust!,
gauges.......2 clusters
92-SENTRA SE-R i miss my sentra!
PROJECT 510
KA24DE.......SOON TO BE TURBO!
