Old 11-06-2004, 09:18 AM   #1 (permalink)
Mean Machine
Advance Timing Questions
My Friend has an NX and he has done what i think is called advance timing. Basically his revs idle at 1500rpm constantly.
I am the better driver than anyone in my group of friends and so i beat him by 3-5 car lengths when he was idling the same. i have done so to most nx's in my area.
I raced him the other day after he upped the timing and he beat me by a small amount.
My Questions
1) Does advance timing make such a great difference ?
2) Does it damage ur engine ?
3) Whats a good rpm idle level ?
4) How do u guys launch your sr20de motors ? How do u perform your best take off ?
Any help is always appreciated.
Coming Soon...
EVL-NXR is offline   Reply With Quote
Old 11-06-2004, 09:50 AM   #2 (permalink)
Master Cunnilingust
Trader Rating: 37 (100%)
Advancing timing is when you adjust the timing forward, like from 15 degrees to 17 degrees. I don't understand how revving his engine at 1500 rpms, which is barely higher than idle, would do anything. Launching most cars at that rpm would be hindersome if anything and there's now way to drive the car at a constant 1500 rpms.
- Rob
Old 11-06-2004, 11:02 AM   #3 (permalink)
Mean Machine
I dont understand what advance timing is now... which section of the block. can u show me a picture of where ? sorry but i really wanna understand what it is since i am totally wrong... I love learning new things about cars. So changing ur idle time from normal isnt advance timing ??? i feel like a newb. So does advance timing make a big difference ??? and to what ?.
By the way he drives his car constantly above 1500rpm, will this damage his engine. And is this a substantial advantage. I mean he beat me by half a car so it must be improving his driving. It seems as though it is to me!
Old 11-06-2004, 11:23 AM   #4 (permalink)
aka Mr Ryte on G20.net
http://www.sr20forum.com/technical-information-library/81413-how-adjust-your-timing.html
http://www.g20.net/forum/showthread....threadid=13470
Vehicle:1995 Dark Green Infiniti G20
Real name:Howard Wright
Current mods:91 intake cam at 19* degrees, TopSpeed header, M3-style rear wing, P11 rims, *Recaro LS-L seats*
I.C.E.:Pioneer DEH-P6800MP CD/MP3 HU, Audiobahn AS65Q 6.5" components in front & back....HELLZ YEAH!!!!
"THOU SHALT NOT MOD THAT WHICH THY CANNOT MAINTAIN" -thus speaketh Mr. Ryte
howard_w13 is offline   Reply With Quote
Old 11-06-2004, 11:31 AM   #5 (permalink)
Mean Machine
yep i been there ? it doesnt explain what advance timing is ? i want to know what it affects.
Thanks for the help, also i was wondering if anyone in australia would like to help me do this. I read the TUTORIAL but i am no way confident
Old 11-06-2004, 11:37 AM   #6 (permalink)
http://www.se-r.net/engine/about_timing.html
Old 11-06-2004, 12:37 PM   #7 (permalink)
Mean Machine
thanks mate, so it improves throttle responce cool. i think i want mine at 17 degrees in case i get the ecu later. i want someone to do this for me. i live in sydney australia ?
Old 11-06-2004, 11:12 PM   #8 (permalink)
Mean Machine
Guys but my main question is does advance timing involve the idle revs going up ? cause my friend claims to have done the timing and his revs are stable 1500rpm.
any help is appreciated ?
Old 11-07-2004, 01:42 AM   #9 (permalink)
Mean Machine
who ever moved this thread, thanx. now i dont think anyone will answer my questions since no one answers any questions in this section of the forum
Old 11-07-2004, 02:23 AM   #10 (permalink)
sleeper
advancing the ignition timing has absolutely nothing to do with the idle. The only reason you should be idling above 800rpm is if you have some cams with extreme overlap and the car won't idle otherwise.
advancing the ignition timing changes when the spark goes off relative to crank angle. you want it more advanced (before top dead center) at higher rpms. more to it, but i'm sleepy
Khiem
'05 Evo
'05 CBR 600RR
Old 11-07-2004, 04:39 AM   #11 (permalink)
Mean Machine
spdracerUT now i fully understand... u are a legend mate. Thanks
i am still hoping for an aussie person to do this for me
Old 11-07-2004, 04:49 AM   #12 (permalink)
I lied, I suck.
man, my advice is this...get a timing light and a 12mm wrench and jump on in. plenty of threads on how to do it, and it's really easier than it sounds. you'll be happier for it.
crashjust4kix is offline   Reply With Quote
Old 11-07-2004, 06:48 AM   #13 (permalink)
Mean Machine
where can i buy these tools from, a hardware store ? walmart which we call kmart ? i am not sure where to get these parts ?
Old 11-07-2004, 07:01 AM   #14 (permalink)
I lied, I suck.
best bet would be an auto parts store. if $$ allows, look for a "dial-back light", they make it a bit easier on our cars since there's no absolute 17 degree mark. they're usually a few dollars more, but you'll be suprised how many burgers/beers/smokes your friends will trade to use it for a day, so it's well worth it. as for the wrench, any hardware store should have one.
Old 11-07-2004, 08:01 AM   #15 (permalink)
Mean Machine
i was just reading throu the g20 forum tutorial and its kind of confusing.
1) does the timing thing i am meant to turn look like this ?
2) Does the timing thing actually have the mark for the number of degrees like 0 5 10 20?
3) What the hell does this have to do with anything, what the hell is it ?
http://www.g20.net/gallery/data/3036...butor_bolt.gif
Old 11-07-2004, 03:25 PM   #16 (permalink)
That is the crank pulley. It does have those marks on it. You shine the timing light onto the pulley from above it. It is on the side of the engine, so you open the hood and just lok straight down on it. Then you turn the distributor, which is on the other side of the engine. The pulley is spinning at engine speed, but you will see the marks move either back or forth-depending on if you are advancing it or retarding it. To put it at a specific degree, there is a thin pin/needle sticking out right above the pulley, so you line that pin up with the timing degree you want. You have to estimae the degree if trying to get somewhere between 15 and 20, but its not hard to get.
Wes
1998 Black 200SX SE-R - Hotshot CAI, UR 2-set pullies, Front and Rear STB, Hotshot Gen 5 Header, B&M Short Shifter, Homemade Grounding kit
Auto -> Manual swap info here
Wes 98200sx ser is offline   Reply With Quote
Old 11-07-2004, 10:45 PM   #17 (permalink)
Undecided
You need to buy a Factory service manual and follow the instructions on how to set the ignition timing. Or follow the instructions on SE-R.net.
Basically you just get the car in timing mode. Then adjust the Distributor until you get it to where you want it. You will verify the timing with a Timing light via the marks on the crank pulley. When you shine the light down there while the car is still running you will see the pin sticking out and pointing at how much advance you have. 15 is stock and you can go up to 19 depending on your quality of gas. Most people run 17-18 on 92-93 octane. If you have better gas like 95-96 then run 20 degrees. You'll notice a nice jump in power.
97SE-R
1/8 8.6@ 85
R.I.P. John
97SE-R C2 is offline   Reply With Quote
Old 11-08-2004, 01:48 AM   #18 (permalink)
Mean Machine
thanks alot
Old 11-08-2004, 03:03 AM   #19 (permalink)
Learn to swim
Just my experience on the subject. On anything I have ever worked on, advancing the timing has increased the idle. Some cars more than others, but it always has, in my experiences. Basic rule for sr20's: If your cars in timing mode, adjust the idle anyways. It won't take more that a min. to do and is easy.
-Josh
-Bill Hicks
UNDRCOVR is offline   Reply With Quote
Old 11-08-2004, 03:42 AM   #20 (permalink)
Mean Machine
i just want my timing advanced and want my idle to remain thesame...
