Old 11-06-2004, 05:12 PM   #1 (permalink)
We Goofed
Oil Pan Baffle
I've got a new oil pan and an oil temperature sender that I'd like to install. I (obviously) need to find a time that the car can sit for a while to allow the liquid gasket to cure. However, prior to doing this, I want to put a bung in the oil pan to receive the oil temp sender. I figured the best place to put it would be in the rear of the pan (figuring I'd be keeping it away from getting ripped out by any road debris I might happen to run over) but the shop I took it to (thank God) asked me if I'd be interfering with the baffle. I know a friend had bunged another oil pan for me (which I subsequently screwed up) but don't remember where that bung was. Does anyone have an idea as to where the best place would be to put a bung for a sender that's sticking into the oil pan by (from my recollection) a half inch or so? I don't want to pull the oil pan off, figure it out, put it back together, wait for it to cure, get the bung welded in, and then start all over again... I want to do it once and only once - the right way! Any help is mucho appreciated!
kieran
95 200SX SE-R track car, 02 Maxima SE, 08 FX45, 08 G37
kieranlavin is offline   Reply With Quote
Old 11-09-2004, 03:02 AM   #2 (permalink)
Geo I am a moderator
NISsport
Geo's Avatar
Kieran, I think if you put it an inch or two off-center you should be fine. You'll want it relatively low to be sure it isn't being uncovered.
George Roffe
91 SE-R (well modded)
http://www.nissport.com
Geo is offline   Reply With Quote
Old 11-09-2004, 01:29 PM   #3 (permalink)
We Goofed
George - inch or two off-center in EITHER direction or one in particular? And thanks for the reminder to keep it low. Don't want to be too low though
Old 11-09-2004, 01:57 PM   #4 (permalink)
Trader Rating: 53 (100%)
My pan is currently at the welders getting my bung welded in. If you are looking at the pan from the front of the car it would be in the driver side rear corner of the pan. it is low enough to be covered by oil and won't interfere with anything else.
PS: watch out for the oil pickup also.
Old 11-10-2004, 02:58 PM   #5 (permalink)
eric96ser's Avatar
Trader Rating: 16 (100%)
I have mine installed on the flat part, right above the drain plug.
1991 Sentra SE-R
The community is here.
Old 11-11-2004, 11:13 AM   #6 (permalink)
We Goofed
Another thing I'm just thinking of now… if I'm slightly off and there is a discrepancy between the temp sender and the baffle, I can notch out the baffle, right? That shouldn't be a problem if need be (I'm assuming)
Old 11-11-2004, 12:05 PM   #7 (permalink)
eric96ser's Avatar
Mine is far enough down, to where is doesn't come near the baffle. I have a picture at home.
Old 11-11-2004, 12:33 PM   #8 (permalink)
We Goofed
THANKS
Old 11-11-2004, 12:53 PM   #9 (permalink)
www.FAIRTAX.org
paNX2K&SE-R's Avatar
Trader Rating: 66 (100%)
Kieran, mine is right above the drain plug also. I just copied what Eric and Steve did
91 SE-R w/DET
02 G20 Sport 5spd
94 Miata "homobile"
93 240SX Family Project
Old 11-12-2004, 09:27 PM   #10 (permalink)
Not the best pics in the world but here is mine.
Old 11-12-2004, 09:31 PM   #11 (permalink)
We Goofed
Oh you da man! Thanks a lot. Now that I see that, I recognize the location
I feel stupid now
Old 11-13-2004, 12:25 AM   #12 (permalink)
eric96ser's Avatar
Did you only tap the pan, and not add anything else?
Old 11-13-2004, 02:16 AM   #13 (permalink)
Maybe I am too tired to understand what you mean? I had the welder drill a hole in the pan. Then he added his own bung and welded it on the outside of the pan. He also spray painted it all black so it looks really clean. He did that and added another bracket on my Spearco for $25.
Old 11-13-2004, 10:00 AM   #14 (permalink)
eric96ser's Avatar
Oh, ok. I thought you just had the sensor threaded into the pan with nothing else. I had a piece of 3/16" steel welded to the inside of my pan, then threaded the hole for the sensor into that.
Old 11-23-2004, 08:03 AM   #15 (permalink)
We Goofed
Anyone have an idea as to a good source for a bung that I can buy and bring to the shop of my choice?
Old 11-23-2004, 01:07 PM   #16 (permalink)
My SR's are Multiplying!
do you know what size you need? 1/8 NPT?
anyway, go to Jegs.com or summitracing.com and search for "weld bung", they have a few of those things. Obviously get one that is steel.
Aaron S.
1972 Datsun 510 W/S13 SR20DET
1997 240sx
1991 Sentra SE-R Project: Anti-Bling (SOLD!)
compression is offline   Reply With Quote
Old 11-23-2004, 01:15 PM   #17 (permalink)
BIG-NUTTED Classic
1fastser's Avatar
Do already have the gauge? My gauges came with several different fittings...I just had one of those welded onto the pan.
Otherwise, what compression said...
*DONE!*
The Beast.
Old 11-23-2004, 01:31 PM   #18 (permalink)
eric96ser's Avatar
What Steve and I did was go to Home Depot, and get some 1/8 steel, and cut the amount you need. I then drilled a hole in it, and tapped it for the sensor.
Old 11-23-2004, 01:56 PM   #19 (permalink)
We Goofed
I'm not doing what you guys did... you're ghetto! :-P
Yes, the size is 1/8" NPT. I'll try jegs and summitracing. I had a brain freeze this morning and couldn't think of some of the standard sites
Old 11-23-2004, 02:00 PM   #20 (permalink)
eric96ser's Avatar
Yeah, like you and Ray aren't the same way. I've seen your "spring compressor" video. That was along the lines of "hey,y'all, watch this."
