Old 11-07-2004, 01:58 PM   #1 (permalink)
"shift_happens"
Trader Rating: -1 (0%)
Will NX2000 struts work a B13 SE-R?
Will a set of NX2000 struts work on a B13 SE-R or is the weight of each car to different?
91 sentra se-r,sr20de, p&p head, balanced internals, 2.5" catback, unorthodox pulley set, fidanza flywheel, short throw, strut tower brace, HS CAI, aftermarket mounts, nx2000 brake upgrade, weaponR header, ebay steering wheel, minor weight reduction...
james_se-r is offline   Reply With Quote
Old 11-07-2004, 02:08 PM   #2 (permalink)
not my president
yes they will work a nx2000 is a b13
1992 nx2000:White: Sold
Danielle Wilson 2/10/07
Old 11-07-2004, 02:19 PM   #3 (permalink)
"shift_happens"
I know but just thinking of the different shape, you would think they wold have differant weight distribution.....
Old 11-07-2004, 02:20 PM   #4 (permalink)
not my president
well i had stock se-r rears on my nx it was fine.
Old 11-07-2004, 02:24 PM   #5 (permalink)
"shift_happens"
sounds good thanks for the input
Old 11-08-2004, 10:00 AM   #6 (permalink)
Her 1st track day in 2017
Fosters's Avatar
Trader Rating: 41 (100%)
If you use stock NX springs in the front, the SE-R will ride higher in the front b/c the NX does have more weight in the front. Physically, both will bolt right up w/o any problems.
Josh
'95 G20 - daily driver
'92 NX2000 - Money Pit
Izzy's Cages---------------Custom Steel---------------G Spec
