Old 11-22-2004, 12:13 AM   #1 (permalink)
TeSeR36
Hesitation throughout power band???
i just bought a red 94 SE-r. and when i full throttle, it hesitates to rev. its like a slow rate of revving...it feels like a have a clogged fuel filter. but i just replaced it and it still keeps on doing it. i am thinking it could be 2 things, ether a vaccum leak or my injectors are not opening corrctly. also **** the OHM reading on stock injectors?..if ne 1 could help that'll be good thanks.
02 Silver Civic Si(totaled it) (worst week ever)
93 blk SER(DET) SOLD!!!(well kinda)
94 AzRED SER(gtir DET)(traded for 200sx ser)
96 200sx(uk motor)(hit then sold )
94 AzRED SER(SOLD!!!)
93 altima (DD)
92 BLk GMC typhoon(New Project!!!)
mickeyj36 is offline   Reply With Quote
Old 11-22-2004, 12:16 AM   #2 (permalink)
agent camel toe
mines does that once in a blue..sounds like a bad injector.take it to a shop and plug it into a scanner.i also replaced the fuel filter.ill let u know cause im going tomorrow
nyce1s.com
R.I.P. RESPECT SR.
93 p10 jdm de--for sale
96 b14 det--for sale
89 formula--sold
next up is a minivan
Old 11-22-2004, 12:09 PM   #3 (permalink)
sleeper
I think the the injectors are 9-10 ohms. Can't remember. You can search for it. Your problem could also be a lack of spark; so spark plugs, wires, or distributor cap and rotor.
Khiem
'05 Evo
'05 CBR 600RR
Old 11-23-2004, 01:49 AM   #4 (permalink)
TeSeR36
ight thanks....yea i checked my spark plugs and they are foul as hell. another question i have is i have a rubber line running from the back right side of the block coming upward. It leads to nothing and i am thinking what the hell is that. I checked my plenum and vaccum lines n i can't figure *** its for. Remeber i have a 94 ser de. so dont mix it with 92 or 91. and another thing ohming the injecters on the 94 is a bit*h in a half. there gotta be an easier way...ight thanks guys
Old 11-23-2004, 01:51 AM   #5 (permalink)
to answer a couple of questions for you
a) Good injectors OHM at 10-14 any higher and they are no good
b) check you vaccum (should be about 15-20 mm/Hg at idle)
c) i would also replace distrubtor cap and rotor like T bags said
d) change your spark plugs -- i noticed that i had a "miss" at around 4k rpm, relpaced plugs with new platinum ones and the miss is gone and the car fells better all around
e) Check your fuel pressue (idle ~36psi, into throttle ~44psi this of course all depends on temperature colder temps increase fuel pressue)
----Edit---------
easy way to check ohms of injectors is to do it at the ECU, pull off the harness and just ohm it that way
ill see if i can find my diagram
------end edit-----
regards
joe a.k.a WigGy .ak.a WiGgleS
best of luck to you and let us know what you find
g20 mods
- front and rear stB that i made
- LCAB that i made
- battery in the trunk
- OBX Header
- Thule Bike Rack
- Fidanza Flywheel
- Unorthodox racing pulley set
- Short Shifter -- with my old 300zx shift knob
- Apexi TT
- JWT s3 cams
- ADDCO sway bar
- P11 12 spoke 15" wheels
- Tinted windows
- Infinity Speakers 4x6 F, 6.5 R
- Hotshot CAI
wiggy is offline   Reply With Quote
Old 11-23-2004, 09:33 AM   #6 (permalink)
TeSeR36
Ight thanks.....appreciate it...i'll tell u guys how it turns out....
Old 11-24-2004, 11:08 AM   #7 (permalink)
84.7 hp
ecoshardcore's Avatar
Approved vendor
i have the same thing, i replaced the oxygen sensor,plugs,wires,distributor cap,rotor,cleaned egr,cleaned throttle body, and every vacuum line on the engine so tell me when you find the problem
ecoshardcore is offline   Reply With Quote
Old 11-24-2004, 11:12 AM   #8 (permalink)
wait...i have a honda?
NismoSER's Avatar
Trader Rating: 17 (100%)
Sounds like the transmission vent tube.
Chris
'91 VVL-powered SE-RSOLD
'04 G35 6MT
'99 CBR600 F4
Old 11-24-2004, 12:09 PM   #9 (permalink)
agent camel toe
yeah the trans vent tube is right over the clutch cable..its loose like u said/i would most definitely buy the inline fuel gauge so u can find out ur fuel pressure.after doing ur routine maintainence + o2 then take a look at exh system(cat converter).i dont know how to tap into ur injectors without splicing them, so good luck.also check ur timing...keep up the post and well answer to our best knowledge
Old 11-25-2004, 11:39 PM   #10 (permalink)
TeSeR36
yea i thought it could be my vent tube....im gonna check that next...but i asked around a lot n one of my friends said *** it is the injecters....i have n extra set so i ohm'd it out and it was @11...n later tongiht im gonna ohm the injecters on my car....i also checked all vaccum lines to see if there was a leak...im summing it up to be 1(or maybe possible all or 2) is the problem....Injector is not opening(or if it is the pulse width is off)/the vent tube/or ignition ish. I'll keep it posted.
Old 11-25-2004, 11:43 PM   #11 (permalink)
TeSeR36
oh yea i still gotta check the cat if there is ne pressure coming back...another thing if it is my tranny vent tube *** do u suppose is wrong with it....clogged..lossed....cracked????
Old 11-26-2004, 02:43 AM   #12 (permalink)
NismoSER's Avatar
The transmission vent tube is just that, it doesn't affect how your engine runs so you can pretty much eliminate that off of your trouble shooting list. Newer transmissions don't even have a tube like that, they just have a little cap that acts sort of like a valve.
Old 11-27-2004, 10:45 AM   #13 (permalink)
TeSeR36
ight thanks.....yea i installed some new spark plugs(auto light double platinum, couldn't afford NGK's n its ok *** imm swap the engine soon) and it made the car run better, but it still has a little hesitation and surging...i am waiting for the plugs from the dealership n i should be getting it on tues.....i'lll keep it posted
Old 11-28-2004, 11:46 AM   #14 (permalink)
Whens the last time you changed you air filter? Also I would check, the resistance in ignition secondary (after the coil).
Mark
95 se-r, avenir, HS fmic piping, spearco ic, calum realtime ecu, 3" jgy dp, 3" inlet magnaflow with 2 2.5" outlets out front each rear tire, walbro, nismo fpr, summint fpg, 2 10" pusher fans, koyo radiator, ats comp lites wrapped in azenis, on tein basics w/ pillowballs up front. Now featuring a gt2871r on JGY mani, and S3 cams!
ser_smokes_alot is offline   Reply With Quote
Old 11-28-2004, 08:28 PM   #15 (permalink)
TeSeR36
yea **** pik up another filter but i really dont think that is it....and *** should the resistance be on the ignition??
Old 12-11-2004, 06:50 AM   #16 (permalink)
SR20DE Rocks
Same prob
Same problem with my 98 SE-R everytime I reached 4500 rpm. I got me a used NGK wires from a guy who wrecked his SE-R and Used the wires for only 2K and he included the Dist cap. So I decided to replace my dist. cap as well since all the wires are hooked already. I guess my car is running good everytime I punched it I didn't even notice the hesitation anymore. Im using the same plugs as what you are using( Autolite Platinum) hey its on sale My next step is to replace my O2 sensor cause I have my engine light on, and I hate to wait longer just to warm the cat so I can have a smooth ride. Oh one more thing, check your throttle cable to.
Prepsx is offline   Reply With Quote
Old 12-11-2004, 09:02 AM   #17 (permalink)
agent camel toe
the surging was solved for me with a bottle of throttle body cleaner and speaker wire..clean ur egr valve.. if its not functioning correctly i will surge..here the link to it from ser.net linxx..it worked for me and i beforehand did a full tune up/o2/ and all full synthetics..as far as ur injectors i dont know how to check the voltage without splicing the wires..good luck and keep the sr20's rolling
