Old 11-22-2004, 12:57 PM   #1 (permalink)
bumpstops
ok i just put in a set of tein s.tech lowering springs in to my 98 sentra se , they drop the front 2.4 inches and the rear 1.1 to fill in that ugly fender gap in the front , well the backs are fine thay have plenty of travel , well the fronts are riding on the bumpstops , i know the bumpstops were not cut and they need to be so i need to know where they are , are they actually on the piston of the strut ? or somewhere else if so do i have to take the suspension out of the car again to cut them , if anyone could provide some pics or any info i would really apreciate it , i'm sorry for such a retarted question , this is the first time i ever lowed a car i owned so i'm not sure about it since i never screwed with the suspension
98 Sentra SE
2 1/4 inch catback exhaust
Kyb gr-2's on stock springs , to much travel for work now
RottdogSER is offline   Reply With Quote
Old 11-22-2004, 01:13 PM   #2 (permalink)
Mexico = Nissanland
It's a doughnut around the piston of the shock.
There are 2 ways to increase the travel of the shocks:
1° Cut the bumpstops not more than 30% of their total lenght &
2° Get Koni bumpstops from Mike Saiki, Motivational Engineering, This is my choice, mmm well was & will be, because I need to pick them up as long as many other parts waiting for me at my Mailing Address at McAllen.
I wish this helps you.
If you need help cutting bumpstops, or finding bumpstops, post & I'll look for some links.
Take a look at here: http://www.nissanperformancemag.com/...ber04/b14susp/ it was maded by a SR20Forum member
Sentra GSS 2000 (B14) SR20DE'ed / X-Trail 2004 (T30) QR25DE'ed
manuelgaMex is offline   Reply With Quote
Old 11-22-2004, 02:48 PM   #3 (permalink)
yeah i need some help on cutting them and finding them first i know how much needs to be cut , according to tein 1.2 inches off the front and .8 inches from the rear
Old 11-22-2004, 03:23 PM   #4 (permalink)
Mexico = Nissanland
Take a look at the above link & also at Kojima's Garage Suspension section: http://www.sentra.net/tech/garage/
I guess at NPM, 200sx GA16turbo proyect there's also some info about cutting bumpstops.
Sometimes bumpstops came in one piece with dust covers, that's why it's a little bit difficult to identify them as a separate part, I'm 80% shure (from FSM) that's OEM case.
Old 11-22-2004, 03:32 PM   #5 (permalink)
i got it , thank you very much for your help i greatly apreciate it
Old 11-22-2004, 03:37 PM   #6 (permalink)
SR20VE or a T28? I dunno!
Don't forget that Energy Suspension makes Bump Stops too
Sam Bass / 1998 200SX SE-R
Atlanta, Georgia
98SERwTricks is offline   Reply With Quote
Old 11-22-2004, 04:52 PM   #7 (permalink)
i see that they make them for the b13 , but will those fit the b14
Old 11-23-2004, 03:21 AM   #8 (permalink)
Canuter Valve Specialist
Sco0terzsl's Avatar
I just put koni bumpstops on my fronts (still need to do the rears though). It's a night and day difference though!
Sco0terzsl is offline   Reply With Quote
Old 11-23-2004, 09:17 AM   #9 (permalink)
i've seen the koni bumps , i was thinking about the es bumps cause there cheaper , since i'm working with a budget here , but i don't know if the es ones will fit since they are for the b13
