Old 11-22-2004, 01:13 PM   #1 (permalink)
Old head
Squeaky Clutch pedal
I've lubed the hell out of this thing & it still squeaks. Anybody got some ideas. Clutch is on the way out anyway.
man...since 2001 dizam I'm old.
John Doe is offline   Reply With Quote
Old 11-22-2004, 03:43 PM   #2 (permalink)
P10 pro
I got the same problem, it appears that the sqeaking is from the spring on the pedal. At first, I thought it was my clutch cable but after removing the cable it still sqeaked. Lubing the hell out of the spring helped temporarly, the squeaking returned. My suggestion is to replace the spring.
5speed is offline   Reply With Quote
Old 11-23-2004, 03:30 AM   #3 (permalink)
SE-R GREEK
If you have been using a stiffer clutch setup then maybe you should investigate and try something like that...
http://cgi.ebay.com/ws/eBayISAPI.dll...e=STRK:MEWA:IT
Chris
Old 11-23-2004, 05:17 AM   #4 (permalink)
GT2835R
Mine does the same sh*t. Its more of a creaking the a squeak. Happened right after the new clutch too.
Rey Uy
99 SE-Limited
Old 11-24-2004, 12:16 PM   #5 (permalink)
agent camel toe
same thing here..i used this blue grease from the dealer on the pedal spring and it stopped
nyce1s.com
R.I.P. RESPECT SR.
93 p10 jdm de--for sale
96 b14 det--for sale
89 formula--sold
next up is a minivan
Old 11-25-2004, 01:19 AM   #6 (permalink)
Technician and Enthusiast
You either need to lube the spring, or buy a new clutch cable and run some penetrating lube hrough the cable shielding. I've had experience. . .
Coheed is offline   Reply With Quote
