Old 11-22-2004, 07:44 PM   #1 (permalink)
GUNT SMASHER
Trader Rating: 4 (83%)
B13 Power to manual steering rack swap
My B13 SE-R power steering rack has started to leak pretty bad. Now is the time to swap in a manual rack and get rid of the PS. Is swapping in the manual B13 rack worth it, or should I just make it easier and get the RTR PS eliminator kit?
Built, not bought.
Aero Deck is offline   Reply With Quote
Old 11-23-2004, 08:49 AM   #2 (permalink)
I completely removed the PS from my car. I'm just using the open power steering rack, and I like it alot.
http://phatboyaudioonline.com/
1993 NX2000-5SPD SWAP, 2120lbs. JDM Motor, Calumsult Realtime ECU, Brian Crower STG 3 cams, CP XTP 9.2:1 pistons, NX DP-100 shot, Prothane Mounts, ACT Xtreme/street disc, PR CAI with JWT POP, SSAC with 2.5" downpipe, Dynomax 3" muffler, Outlaw Intake Spacers, OEM wires with ngk plugs, UR Pulleys, Walbro 190, ST springs with KYB's, Xstatic Batcap, Axis maglites
Old 11-23-2004, 10:59 AM   #3 (permalink)
Her 1st track day in 2017
Fosters's Avatar
Trader Rating: 41 (100%)
I did the same thing as AaroNX, and I'm not 100% satisfied w/ it yet; but it could be b/c I drive my daily driver SE-R the most which still has PS. Personally, I would like to drive a manual rack'ed car before dealing w/ the change.
Josh
'95 G20 - daily driver
'92 NX2000 - Money Pit
Izzy's Cages---------------Custom Steel---------------G Spec
Old 11-24-2004, 09:21 AM   #4 (permalink)
That's about how I am. I'd rather have a manual rack, but I'd like to see how it would feel first. I'm happy with it for now though.
Old 11-24-2004, 10:20 AM   #5 (permalink)
I personally have installed a manual B13 "E" rack. It is pretty good for daily street driving, its not that big of a deal or difference.
For the install- you have to change out the steering coupler between the rack and column. I actually used a coupler from a 1990 (B12) Sentra, as the stock will not fit.
Good idea on the RTR kit, but if you are on a budget use the old pump with the lines removed and blocked temporarily.
Chris M
Va Beach, VA
91 Classic Turbo
93 NX2000-work in progress
Projnx2000 is offline   Reply With Quote
Old 11-25-2004, 10:08 PM   #6 (permalink)
Fosters's Avatar
Dustin Buell also sells PS removal kits. He has some bad feedback, but I can't complain about the guy. I believe his screen name is Twowheeltirefrier (or something like that). I'm running his kit, and I haven't had any problems.
Josh
Old 11-25-2004, 10:56 PM   #7 (permalink)
I've seen his kit on here before. I think it's just Twotirefryer. I like the fact that both guys went to the trouble of making those kits, but I'm having no trouble with just the smaller belt on just the wp pulley. For a LONG time I just had the stock PS pump hooked up to nothing at all and it worked fine as well. I just removed it and went to the smaller belt for weight reduction purposes. Well and I mounted my battery on the firewall right there.
Old 11-26-2004, 01:25 AM   #8 (permalink)
Gone!!!
Trader Rating: 24 (100%)
I had the p/s removed on mine and prefered to keep the Se-r rack since it had a better, tighter steering ratio. If your going to buy a new rack I would consider just buying one for the Se-r. When I deleted my p/s, I kept what fluid was in the rack and ran a rubber hose to the 2 fittings on the rack and just allowed the fluid to recirculate in the rack.
93 NX2000 VE
08 Frontier Se
BORNGEARHEAD is offline   Reply With Quote
