Old 11-23-2004, 08:29 PM   #1 (permalink)
The road's my slave
*squeaky suspension urgent!*
i have a 93 nx2000 with intrax springs and kyb gr-2s all around. i dont know the drop measurements or the spring rate cause i bought the car as is. but recently i've been hearing squeaking from the driver side rear and it worries me and it also annoys me. what makes it worse is that i'm driving around with tires with flat spots in the rear. so it's a pretty bumpy ride. i used to only get the sound when there was weight in the rear but now it's constant. please help.
P.S. could a bumpy ride cause the studs to loosen up?
ChrisNX2000 is offline   Reply With Quote
Old 11-23-2004, 08:45 PM   #2 (permalink)
Same problem
If it helps any I have a different setup (AGX with pro-kit) but same problem in the right rear strut. I get a (very) annoying squeak while driving. I'm almost positive its the strut mount, which looked worn out when I installed the AGX. If that's the case it really isnt anything to worry about unless it gets much worse or the sound really gets to you.
1992 Nissan NX2000
AEM CAI, SSAutoChrome Header, Custom 2.5" Exhaust, Magnaflow RaceSeries Muffler, Timing @ 17 degrees, 17" Enkei RS5s, 205/40/17 Yokohama Avid H4, Eibach Pro-Kit w/ AGX
Future Mods: S4 (or hopefully S5) cams, UR Pullies, New Clutch, Fidanza Flywheel.
scifinova is offline   Reply With Quote
Old 11-23-2004, 08:47 PM   #3 (permalink)
The ELITE NX2k Bredren!
Trader Rating: 26 (100%)
From what I have heard. Your struts sqeak when they are blown. You might want to check into that...
1993 Nissan NX2000
w/ 1998 SR20DET Avenir motor w/ so many mods it would be stupid to list them all and more coming!!!!!
Johnny wangwang is offline   Reply With Quote
Old 11-23-2004, 08:52 PM   #4 (permalink)
The road's my slave
hmm, are there any other signs to look for in a blown strut? just to let you know i dont do any hard driving.
Old 11-23-2004, 10:08 PM   #5 (permalink)
You like that, dontchya?
It also could be your top mounts for the suspension. Those are made out of rubber and can squeak when a stiffer suspension is installed.
Antonio G.
BLACK 91 SE-R w/ DET, 7psi - 13.9@101.9 on streets, 206whp/196wtq
WHITE 91 SE-R for daily driver action
AntonioG is offline   Reply With Quote
Old 11-23-2004, 10:24 PM   #6 (permalink)
The road's my slave
doesn't sound like rubber squeaking
Old 11-23-2004, 10:26 PM   #7 (permalink)
yeah i have that same sqeak only its in the right rear, my guess on mine is worn struts they need to be changed, but the top mounts would be a good place to check also over time all the bushings will wear too. a decent way to check your struts is to push down on the rear of the car and see if it bounces. if it comes back into place without bouncing i would say your struts are fine. it seems as though this is a common problem so im sure someone has tracked it down by now. good luck!
nx2blue4u is offline   Reply With Quote
Old 11-23-2004, 10:28 PM   #8 (permalink)
The road's my slave
thanks people. now how about the bumby tires. will they make my lugs loose?
Old 11-23-2004, 11:17 PM   #9 (permalink)
DBA/IT
Trader Rating: 19 (100%)
yes, a bumpy ride will tend to loosen things up. Both of my rear strut mount nuts (the big ones in the center) loosened up over time, causing my mounts to clunk while driving. Hell, even the clip for my sunvisor fell off today as well from all the vibration in my car
http://www.rollyourcar.com
