Old 11-24-2004, 07:51 AM   #1 (permalink)
Living up Boost
front end noise after clutch install
The clutch install seemed to go fine. The clutch engages and disengages great. Feels nice. When I put the car back together and went for a test drive, the only thing I noticed was that my steering was off...I had to turn the wheel to the left a little to go straight...I got an alignment today and apparently my toe was off a snudge and the guy said that has nothing to do with my steering being off...I took his comment with a grain of salt and after I left the place, the alignment was perfect! I guess that problem WAS because of the toe being off...NOW, the other problem is that when I come to a stop, I hear these Ticking sounds like coming from the wheel well area...like something is moving. It also happens when I take off. Any ideas? Sorry for the long post...hear is my alignment specs:
Saaby is offline   Reply With Quote
Old 11-24-2004, 12:12 PM   #2 (permalink)
agent camel toe
do u have abs?it could be the abs sensor hitting the axle.jack the car up and spin the wheels.good luck and keep the posts up
nyce1s.com
R.I.P. RESPECT SR.
93 p10 jdm de--for sale
96 b14 det--for sale
89 formula--sold
next up is a minivan
Old 11-24-2004, 01:01 PM   #3 (permalink)
Living up Boost
No ABS.
