Hey guys alright so i was driving down the road today and all of a sudden the oil pressure dropped and there was smoke comming out the back of the car. So i pulled over and had to get towed home. Now i get it home and jack it up. Where the Oil pressure Sending unit goes. The adaptor cracked. SO there is part of the adaptor in the hole. It is not sticking out anywhere so i cannot grab it with anything. Please i need help of ways you think to get it out.
Situations get worse before they get better.
I would try a flathead screwdriver if you can get one down there, you might be able to spin it off that way, or you can get a reversed drill bit and that will pull it, but I don't think there is enough room back there to get to it with a bit. I would try the screwdriver first though..
