Old 11-27-2004, 08:16 PM   #1 (permalink)
KA24DE POWERED
Need Help With Ticking??.....
Ok I have a ticking noise coiming from my engine, that I thought sounded like a bad lifter. So We replaced all the lifters with new Nissan ones, And while in there replaced valve springs as well, all new from Nissan. Set everything back up back to spec and start it up and the Damn noise is still there. The noise goes away after 3000 rpm's in any gear so I thought it was a lifter and after 3Krpms it built up enough pressure to stop making noise, well that apparently isn't it. Anyone have any idea on what to check out next? TIA.
91' 240SX SE HB (19k original miles)
04' Spec V NX 75 Shot (Wet)Totaled
72' VW Bug 2276cc N/A TERROR (In Progress)
90' 300ZX N/A(Sold to Pops)
02' Kawasaki Mean Streak - Kandy Gold Spark(Sold)
91' SE-R::The BEAST in the SouthEast....(Sold)
93' NX 2000:Sold)
BadAzzSentra is offline   Reply With Quote
Old 11-27-2004, 08:28 PM   #2 (permalink)
nx vet
u might have a lower bearing gettin ready to go out
my93nx is offline   Reply With Quote
Old 11-27-2004, 08:48 PM   #3 (permalink)
Tired Greasemonkey
are you sure it's not your tensioner?
Old 11-27-2004, 08:58 PM   #4 (permalink)
KA24DE POWERED
Tick
Your talking about the timing chain tensioner right?
Well I hope not cause this motor only has 1500 miles on it I just had it rebuilt, and the only thing I did not replace with brand new stuff was the lifters and the springs, until now. But I will definately check it out.
Old 12-01-2004, 12:37 PM   #5 (permalink)
Tired Greasemonkey
might want to do a power balance test, and an injector balance test to see if it's not a loud injector or piston slap/cylinder noise.
Old 12-01-2004, 01:29 PM   #6 (permalink)
I lika da turns
I'm no mechanic like some of these guys but those injectors can be pretty loud. The noise could have "gone away" just because going past 3k raised the frequency to where you can't hear it. I know mine were pretty loud when an injector went out on me and then I replaced them and much quieter.
Ben
'05 Subaru WRX STi
'93 SE-R Rocketsled (SOLD)
Drive it like you stole it (or at least try to before it breaks)
http://www.imagestation.com/picture/...1/fa5710dd.jpg
Cannibal is offline   Reply With Quote
Old 12-01-2004, 02:05 PM   #7 (permalink)
Get close to the injectors and check to see I think that it is your injectors cause mine does the same.
F-max stg ll, t3/t4 ballbearing,300zx TT fuelpump,msd digital 6, o2induction stglll IM,intercooler,camgears,UR racing pulleys,JWT program for S-3,waterinjection,race fuel,cobra maf. jwt fuel rail,ES bushingset,Zex flywheel 10.2lbs, ACT clutch, head port/polish with intake bored 1mm and angle job,steel braided brakelines,Arias pistons 8.5.1,eagle rods,80 shot direct port N.O.S. Koyo radiator
boostn92se-r is offline   Reply With Quote
Old 12-01-2004, 02:10 PM   #8 (permalink)
Tired Greasemonkey
get a long screwdriver or pry bar and put the metal end to each injector and put your ear to the handle, and listen up. i'd bet it's your injectors
Old 12-01-2004, 08:10 PM   #9 (permalink)
KA24DE POWERED
Tick
Thanks for the replys and the help. I will check all this out as soon as I get a chance, been busy at work. I will let you know what it turns out to be. Any other things I should check let me know.
Thanks All.
Old 12-01-2004, 08:30 PM   #10 (permalink)
Titles Suck
Sounds like the start of rod knock.... Wait till it gets louder and you'll know what it is... Mine did the same thing at first... but it just got worse.
W10 KIT PART OUT FOR SALE
NoReason is offline   Reply With Quote
Old 02-12-2005, 11:20 PM   #11 (permalink)
SHIFT_psssssssttttt
did u find out what caused this....i have this ticking in my engine too.
might be injectors like some poeple suggested, i think i have a slightly leaky one because my EGR code is throwin a CEL and i know for a fact my EGR works, i also get a slight smell of gas sometimes.
B14 SE-R turo (sold)
350Z (sold)
Evo 9 (new toy)
b14xxser is offline   Reply With Quote
Old 02-15-2005, 02:10 PM   #12 (permalink)
KA24DE POWERED
No, We set up all new lifters on the plate, checked the timing chain & guides, all seems o.k. but I still have the noise . Car runs strong as hell like normal, so I guess I'll just drive it. injectors are o.k. too. And BTW its definately not rod knock or a bearing.
Old 02-15-2005, 02:31 PM   #13 (permalink)
TeSeR36
I say first look at t\what could be causing all those problems....Like some people said rod bearing....yea it could be that *** i had the same problem and i found out the hard way....well i say maybe check oil pressure just to see...there might be some clearance in your bearing-to-journal.
02 Silver Civic Si(totaled it) (worst week ever)
93 blk SER(DET) SOLD!!!(well kinda)
94 AzRED SER(gtir DET)(traded for 200sx ser)
96 200sx(uk motor)(hit then sold )
94 AzRED SER(SOLD!!!)
93 altima (DD)
92 BLk GMC typhoon(New Project!!!)
mickeyj36 is offline   Reply With Quote
Old 02-15-2005, 04:19 PM   #14 (permalink)
mess around with the clutch might be a throwout bearing
M0nk is offline   Reply With Quote
Old 02-15-2005, 05:32 PM   #15 (permalink)
i have a messed up tranny and at idle it makes noise and when i tap the gas it makes the noise real quick and goes away...i have a noise like what u r saying around 3000 rpms and it goes away before and after 3000 rpms. I run the car hard and it has good oil pressure and runs strong....Also, it seems to do it in 1st and 2nd gear.....i cant hear it in the rest of them.
cubanprince1 is offline   Reply With Quote
Old 02-15-2005, 10:20 PM   #16 (permalink)
SHIFT_psssssssttttt
yeap, same exact issues with mine...runs strong, just has loud ticking, just a lil' embarassing when i drive thats all...lolz!
Originally Posted by cubanprince1
i have a messed up tranny and at idle it makes noise and when i tap the gas it makes the noise real quick and goes away...i have a noise like what u r saying around 3000 rpms and it goes away before and after 3000 rpms. I run the car hard and it has good oil pressure and runs strong....Also, it seems to do it in 1st and 2nd gear.....i cant hear it in the rest of them..
i think yours is more of a throw out bearing noise because it is there at idle.
