Originally Posted by nomad
does an sr20ve cams fit on a sr20de
To be to the point...
It would not fit.
The cams are C O M P L E T E L Y different, may pay to check out the 'sticky'...
http://www.sr20forum.com/neovvl-guides/70960-how-vvl-works.html.
And then take a good look at the configuration of the cams (pic #5), the extra lobes on the VVL 'cam' of the cam; you should notice that there are 4 (FOUR) EXTRA lobes per bank, or cam shaft.
Hence the reason why the 'VE' brigade are a WEEEEE bit stuck on cam choices.
Cheers.
