Originally Posted by OnyxEros
Simple question
Does is the 20v piston the same as the 16ve piston? I know they offer the same CR.
No they are not.
SR16VE and SR16VE N1 share the same piston
SR20VE piston is close to a 9.5 to 1 piston but with valve notches
SR20VE 20V has valve notches and is almost a flat top
If you ran SR16VE pistons in a SR20VE the compression would be up at about 14 to 1.
Compression has to do with a few diffrent factors.
1 crank size
2 pistons Size
3 Piston volume example Dish, flat top and dome.
So just because the 20V and SR16VE have the same compression, they have the same combustion chamber volume, they do not have the same crank size and they have diffrent piston volumes.
