Old 02-07-2005, 02:39 PM   #1 (permalink)
SE
Questions for VE nuts
Question #1
Do SR16VE Manual tranny internals fit into 91 DE Tranny
Question #2
Do SR20DE High Port Intake manifold fits on VE Head
Question #3
What do i need to make de DE/VE mix
Thanks you guys, maybee you will convince me to go with a VE head instead of a upgraded valve train DE head
Dowve is offline   Reply With Quote
Old 02-07-2005, 02:59 PM   #2 (permalink)
Trader Rating: 102 (100%)
1 - just use the whole sr16ve tranny
2 - nope, the ports are way different
3 - you can get a VE head/intake manifold and slap it on a VE. the VE is way different on the inside, you cant just put VE valvetrain on a DE head.
Old 02-07-2005, 03:05 PM   #3 (permalink)
SE
that's because I already have a GTIR intake manifold with map sensor convertion and non plenum
Old 02-07-2005, 03:07 PM   #4 (permalink)
So you're just looking to do the ITB setup on a VE?
Old 02-07-2005, 03:09 PM   #5 (permalink)
SE
Maybee swap de VE head on my DE bottom end (11:1, 1mm oversize, GTIR oil pump and girdle, freshly rebuilt)
Old 02-08-2005, 02:34 PM   #6 (permalink)
SE
Do SR16VE Tranny fits into 91 G20 ?
Old 02-08-2005, 05:32 PM   #7 (permalink)
SE
and where is the factory cutt-off on non N1 Sr16ve
Old 02-09-2005, 12:02 AM   #8 (permalink)
seen the light
Yes...and 8200rpm(approx)
search
HP11 VE - SOLD
BCNR33 GT-R - SOLD
HP12 20V family sedan.
S14 all motor track coupe in the pipeline
madandy is offline   Reply With Quote
Old 02-10-2005, 01:10 PM   #9 (permalink)
SE
WItch one is better, SR16VE ou SR20DET GTIR oil pump
Old 02-15-2005, 01:06 AM   #10 (permalink)
SE
and whats the compression ratio of a non-N1 SR16VE
Old 02-15-2005, 01:04 PM   #11 (permalink)
maybe you should learn the search button first.
alex29 is offline   Reply With Quote
Old 02-15-2005, 03:17 PM   #12 (permalink)
Hostile Aberration
Shawn B's Avatar
It's a handy-dandy, indispensable, oh-so-quick, way to find out answers to your questions .
Old 02-17-2005, 01:01 AM   #13 (permalink)
SE
Il already use it and find nothing good
Old 02-17-2005, 11:02 AM   #14 (permalink)
SE-R GREEK
Try it again with "SR16VE" and "CR"...
Chris
