Old 02-10-2005, 09:09 PM   #1 (permalink)
JWT'd now
Got the ecu installed tonite. Took her out for a driver without the cams first and the difference is night and day! Then I hooked up the cams to MSS using Rockwoods directions(work excellent) and it feels just as good. I'm pretty sure my 2" exhaust and OBX header are chokin the crap out of it at higher rpm's. I also have that part-throttle hesitation some people have mentioned, so I'm going to work on that tomorrow. Otherwise i give it thumbs up!
Stabone is offline   Reply With Quote
Old 02-11-2005, 07:26 AM   #2 (permalink)
Congats! It's always a nice surprise when things go well. Good luck with your hesitation. I have a miss under load at low RPM but it seems to have worked itself out over the last few days. Also, it's taking a while for the ECu to figure out the idle. But it is gradually improving.
Bill
Old 02-11-2005, 10:35 AM   #3 (permalink)
eric96ser's Avatar
Trader Rating: 16 (100%)
When are you getting the part throttle hesitation? Mine does that below 2500 all the time, and it is relly bad when the car is cold.
1991 Sentra SE-R
The community is here.
Old 02-11-2005, 01:00 PM   #4 (permalink)
Yep, I'm having the same problem as you. Its was pretty bad this morning. and once it warms up it still has a slight hitch there but its alot better. Funny thing is that my DE ecu didn't do this. I searched on the problem but there doesn't seem to be an answer.
Old 02-11-2005, 01:18 PM   #5 (permalink)
the proof wizard
Trader Rating: 26 (100%)
congrats man
Old 02-11-2005, 01:45 PM   #6 (permalink)
I got this as well.
95' 200SX VE Powered (Sold)
95' 240SX All Suspension
05' 350Z Stock
SE-R-2-Go is offline   Reply With Quote
Old 02-11-2005, 01:58 PM   #7 (permalink)
eric96ser's Avatar
I found out this is typical for a JWT ECU with bigger injectors. I ran the DE ECU with my VE for a few weeks while waiting for the new program. The DE ECU didn't do this at all. I watched the timing with the nProbe, and the timing dropped from being in the 20s, to 5deg or lower, then jumped back to the 20s or 30s. If you increase the throttle at this point, the bucking goes away. If I'm just cruising around, and the rpms drop below 2500, there is a "dead spot" between 2000 and 2500. The timing does a similar drop, but not as bad. I can also feel this dead spot when starting out from a stop. I have SR16 cams, so off the line power should feel better. My '91 feels better off the line than my VE does.
Old 02-11-2005, 02:19 PM   #8 (permalink)
Wonder if the VE ECU does it as well? Somehow I doubt it.
Less is more.
blitzmr2 is offline   Reply With Quote
Old 02-11-2005, 02:30 PM   #9 (permalink)
ClamSlut
Calum's Avatar
Approved vendor
Trader Rating: 24 (100%)
Eric, can you describe in detail what your are doing when you preformed the above test (the one where you saw timing pulled to 5 degrees then jump back)? Are you driving at part throttle then mashing the gas? Doing the same thing with the stock ecu, how much timing does it pull?
I really wish the VE was in your B13.
calum@calumsult.com
Calum is online now   Reply With Quote
Old 02-11-2005, 03:37 PM   #10 (permalink)
eric96ser's Avatar
I'm at part throttle. If you mash the gas, the hesitation goes away. I think I have the log files that show the timing, TPS voltage, and coolant temps. I'll email them to you.
Old 02-11-2005, 04:09 PM   #11 (permalink)
Yep, exactly what happens to me. I took the car for a "spirited" drive today and I have noticed the hesitation with a warm engine has improved. I hate the "cold hesitation" because I literally have to rev the engine beyond 2500-3000 to keep the engine from falling on its face.
Old 02-11-2005, 09:10 PM   #12 (permalink)
Power to spare...
Yep. Same thing here. Part throttle cold...does it everytime. Floor it and it goes away but that is not good to do on a cold engine so you just deal with it until it warms up.
'97 200SX SE-R GT28RS Powered
'06 Mitsubishi Lancer Evolution IX
Thomas Reynolds is offline   Reply With Quote
Old 02-13-2005, 12:43 PM   #13 (permalink)
seen the light
You're right...stock VE ecu doesn't do it. The timing doesn't drop upon throttle tip-in as described but the stock maps sure are conservative.
HP11 VE - SOLD
BCNR33 GT-R - SOLD
HP12 20V family sedan.
S14 all motor track coupe in the pipeline
madandy is offline   Reply With Quote
Old 02-13-2005, 01:12 PM   #14 (permalink)
Turbo-VVL finally
I also just recently swapped ecu's and I have the same hesitiation with both ecu/inj. set up. Mine is a little less noticable w/jwt ecu, but not by much.
b13-sr20ve
I'm one crazy mo-fo, I had to buss a cop *** he wouldn't give me my props in Oak-town.
chirpin4th is offline   Reply With Quote
Old 02-13-2005, 01:58 PM   #15 (permalink)
Like it or Don't Like it
It seems that we are all in the same boat with the jwt ecu...mines does the hesitation too.
I need to warm the car to go out not like the DE just warm it like 30secs to 1 min and it keep going fine..the VE runs crappy cold...but the hesitation once its starting to warm its not that bad...but oh well been 1 year now like that im used to it...just start the car 4-5 mins before going out
NEO-VVL Got VT@K?
E²SR20.com
Digitek is offline   Reply With Quote
Old 02-13-2005, 02:25 PM   #16 (permalink)
Turbo-VVL finally
Like I said mine did it with both ecu's. I don't think the ecu has any relationship with the hesitation.
Old 02-13-2005, 03:11 PM   #17 (permalink)
VE > DE
I had some hesitation below 2500 rpm when cold with the DE ECU. I don't have any hesitation what so ever with the JWT ECU.
B14 SR20VE
ATL-SR20 is offline   Reply With Quote
Old 02-13-2005, 04:49 PM   #18 (permalink)
Neo'ed
My car had hesitation (DE ECU) until i went aftermarket. I think its definatly something to do with the ecu
Old 02-13-2005, 09:18 PM   #19 (permalink)
eric96ser's Avatar
I wonder if you have a different "generation" of the VE program.
Old 02-13-2005, 09:33 PM   #20 (permalink)
Well considering I got my ecu 1 week after him, i doubt it.
