If I were going to build a budget VE, it would be as follows:
Buy a SR16VE
use SR20 crank and rods and RR SR20 pistons
Gen 6 header, JWT ECU, thermoblock spacers.
Use Silvia alternator bracket to remove P/S
Probably good for 205WHP for $3000 or so with the clutch and flywheel.
I think once the JWT cams come out the VE owners will have some good options for a high HP screamer, although rumor has it you need JWT pistons to take full advantage of their cams.
Of course the standard DE add-ons apply, like 300ZX pistons, coatings, multi angle valve jobs, etc.
I am not sure if VE owners can use UR pulleys, their site does not show an application for the VE, although they have an application for the GTi-R, which may or may not fit. Someone like Andres would have the answer to that.
