-3'' exhaust
-fujitsubo header (3-4 months away)
-jwt ecu
-jwt pop charger
-cams (about a year from now)
Here is my question. Will I be ok running the OEM pressure plate with an 01 SE disk? I assume once I get the cams, a new clutch will be required, but for the time being am I OK? TIA.
if youre king clutch smoker, who likes the throttle on shifts, your clutch won't last unless its got metal in it. if you arent hard on them, the stock one works perfectly.
I have a key value setup on my car right now... had an act when i did the swap and it held fine, but took a dump about 2 months ago and ACT was backordered on the HDPP.
It holds the power fine (so far), but i wouldn't go drag racing and try slicks or anything like that with a stock clutch....
