Old 02-24-2005, 01:50 PM   #1 (permalink)
808 SE-R MAFIA
knock sensor on VE
Hey guys,
finally fixed my knock sensor error code on my VE. Too early to tell if it makes a performance difference. The connection had come loose so i simply soldered the wire back to the connector and wrapped it real good. That bugger was a real hassle to get to, behind the coolant line, above the starter and caddy corner to the oil filter. hahahaha Definitely got some bloody knuckes from that one. Anyway, I remember a few of you were getting that error code too so i figured id post. IT didnt look like the connection from the wire to the plastic clip is too solid so maybe you should check that if you are having the same problem.
nathan
sr20sleeper is offline   Reply With Quote
