Old 02-25-2005, 06:44 PM   #1 (permalink)
SR20VE inside
Help needed for MSS
Actually i have got MSS working already one week ago, but today when driving around and testing the car after VE-->DE injector swap, I realised that something is wrong with MSS or wiring, or MSS setings, or...
When I am reving the engine to redline, MSS will start to show 0 rpm frequently from about 6500 rpm. RPM's are like jumping on the MSS screen: 0 and 6845, 0 and 6959, 0 and 7164, ...etc.
On lower RPM's it's works ok.
And of course - solenoids will be deactivated at this time. It feels VERY bad, when accelerating
RPM signal is from coil (green/yellow), I am using only RPM signal for activation.
Any suggestions??
Vahur
N14 Nissan Sunny GTI´92
SR20VE powered rally car...
http://www.foto24.ee/users/vahur
Sunny gti is offline   Reply With Quote
Old 02-27-2005, 03:46 AM   #2 (permalink)
Neo'ed
Mine did that, but we fixed it when we unplugged the smaller plug out of the back of the mss. I think one is for TPS and the other is a ground for the tps circuit, its ok to remove it. I have no idea why it worked, but it did
Old 02-27-2005, 01:10 PM   #3 (permalink)
SR20VE inside
I don't have this plug connected with my MSS...
It pisses me off, and I dont know what to do...
vahur
Old 02-28-2005, 04:01 AM   #4 (permalink)
greek vvl
Take rpm signal from ecu input. It will work fine.
Bill
bill is offline   Reply With Quote
Old 02-28-2005, 04:30 AM   #5 (permalink)
70/30 Racing
Rockwood's Avatar
Any suggestions??
Vahur
do a search, i posted the solution to this exact problem a while ago.
Steve Rockwood
92 G20 - PTD #73
Old 02-28-2005, 05:04 AM   #6 (permalink)
SR20VE inside
thanks Steve, i found it.
Will try it in the evening.
<do a search, i posted the solution to this exact problem a while ago.
Vahur
Old 02-28-2005, 08:36 AM   #7 (permalink)
SR20VE inside
Steve!
Please confirm - the correct wire is pin 3, Y/R, shown on the scematic. This wire goes to resistor.
http://us.share.geocities.com/jjpalm...g_diagram1.JPG
NB! pls copy the link to address bar, just click will not work!
Vahur
Old 02-28-2005, 06:38 PM   #8 (permalink)
70/30 Racing
Rockwood's Avatar
whoops.
you dont have a US car, sorry, i didnt realize that until now.
can you post the actual link or a tiny URL link? my work computer doesnt allow right clicks and the URL is abbreviated on the forum.
Old 03-01-2005, 12:59 PM   #9 (permalink)
SR20VE inside
I did my best, pls try this link, it seems to be ok,
it is wiring diagram for 91-92 Sentra/NX (SR20DE).
It should be 99,99% compatible with my car.
http://foto.k-arvutisalong.ee/klient...6&p=20634 7#s
and the second half of the wiring is seen here
http://foto.k-arvutisalong.ee/klient...6&p=20632 9#s
Pin 3 Y/R wire goes to resistor (marked as F4 on wiring diagram).
Is this the correct wire to connect MSS brown rpm wire to get accurate RPM readings?
regards
Vahur
whoops.
Old 03-01-2005, 05:18 PM   #10 (permalink)
SR20VE inside
I found my wiring diagrams from here, can you open this links?
http://www.sr20forum.com/showthread....ring+dia gram
if it's not ok, please give your e-mail address, i will send them for you!
regards
Vahur
whoops.
Old 03-01-2005, 05:35 PM   #11 (permalink)
Neo'ed
Vahur,
try this apexi link. the n14 pulsar sr20det is the same as my n14 sr20de loom, so i assume its the same as yours:
http://www.apexi-usa.com/productdocu...savcr_wire.pdf
Old 03-01-2005, 06:22 PM   #12 (permalink)
SR20VE inside
Thanks, gary
According this apexi diagram it seems to be pin #2 on ecu, which gives rpm signal to tachometer and not pin #3, which was reccomended by Steve.
I am little confused, maybe both will work?
Steve - pls give your comment!
I want to be sure, befor i'll go to change my wiring.
regards
Vahur
Vahur,
Old 03-02-2005, 09:03 AM   #13 (permalink)
SE-R GREEK
Vahur's diagram... sorry for the size...
Old 03-04-2005, 04:30 AM   #14 (permalink)
SR20VE inside
Thanks Steve
I followed your instructions and SR20DE wiring diagram and rewired MSS rpm wire. Now seems to be ok!
regards
Vahur
whoops.
Old 05-02-2005, 08:02 PM   #15 (permalink)
How exactly are you physically gaining the signal from the RPM wire in question? A vampire connector? Something else?
Less is more.
blitzmr2 is offline   Reply With Quote
Old 05-04-2005, 08:18 AM   #16 (permalink)
SR20VE inside
yes, i used a vampire connector
vahur
