When you go to install it, you need to bend the pipe on the AFPR a little bit for clearance. Do this carefully (I inserted a screw driver into the pipe) and there should be no problem. Also, you will need to notch the little manifold brace so that it clears the adjusting screw. You probably want to make the notch big enough to get a little wrench on the screw.
