Old 03-02-2005, 02:00 AM   #1 (permalink)
merely a flesh wound
chriscar's Avatar
MAF question
Are all the 'newer' Nissan/Infiniti MAF's basically the same? There's a Infiniti MAF for sale on the the forum that I'd like to pick up, I just need to know if JWT will be able to program the ECU to use it.
It's from an M30 VQ30, part number A36-000 N60, the seller thinks it's off a 1992 car.
The thread is here http://www.sr20forum.com/mechanical-oem-part-outs/106732-infiniti-m30-maf.html
Thanks in advance,
Chris
Old 03-02-2005, 07:16 AM   #2 (permalink)
Jah Rastafari
Trader Rating: 55 (100%)
Thanks in advance,
Chris
Leave that MAF alone. JWT is not using that MAF for VEs or anything else. Your choice for the VE is Cobra MAF, SER MAF, 95-99 MAxima and Pathfinder MAF.
Old 03-02-2005, 10:37 AM   #3 (permalink)
Trader Rating: 102 (100%)
Stop being a cheapass Chris, buy the proper maf
Old 03-02-2005, 11:03 AM   #4 (permalink)
chriscar's Avatar
Damn Serb, why so harsh?!?
I've seen people using all minds of different maf's on VE's. I just wanted to know if this one would work.
C:\>
Old 03-02-2005, 11:19 AM   #5 (permalink)
I'm not harsh Get a Pathfinder/Xterra MAF
Old 03-02-2005, 04:19 PM   #6 (permalink)
I dont mean to Hijack this thread... but why do people want to keep using different MAFs and bits from different cars? Is there something wrong with them? What are the benefits of replacing these componants?
The_1_NEO is offline   Reply With Quote
Old 03-02-2005, 04:26 PM   #7 (permalink)
retired
Each maf has a limitation on how much air it can measure, We usually choose a maf based on how much air we need to measure.
NOT SR20 POWERED
needs.
Old 03-03-2005, 10:40 AM   #8 (permalink)
NeoVVL Egg
Now, Im about to purchase a 96 maxima maf with harness for my sr16ve...I am getting a custom ecu flashed...Here is my question....are the maxima maf and pathfinder maf interchangeable, or is there an advantage to the pathfinder maf?
thanks..John
-John-
1992 Nx2000
Sr16ve, Hotshot CAI, VE Exh. Manifold w/hotshot downpipe, 2.5" Megan Racing cat-back, msd window switch, nismo fpr, eibach pro-kits and kyb gr2's, b14 se-r Wheels, Exxd Ecu.
NismoNx2000 is offline   Reply With Quote
Old 05-01-2005, 12:14 AM   #9 (permalink)
the spookman
thanks..John
kinda wondering this myself...
05 Legacy GT
93 NX2000 w/VE
(\__/)
(O.o )
Old 05-01-2005, 12:42 AM   #10 (permalink)
i love b13's !
Trader Rating: 22 (100%)
i spoke to ben at jwt. one of my question were what maf should i run. he told me use a de maf. reason being jwt ran different mafs on a ve on the dyno, he never specified wich ones and he said the they saw 0 difference when comparing dyno runs with a de maf. he told me to run the de maf. now heres a question for you knowledgeable ve guys, such as serban or andreas do u think ben is correct, or is there a difference when running different mafs ?
im back.......
Old 06-11-2006, 06:22 AM   #11 (permalink)
Air Force SE-R freak!!!!!
Dick's Avatar
Trader Rating: 47 (100%)
I'm gonna raise the dead and ask for a reply for this question^^^
95' b14 SE-R: sr20ve/sr16ve N1 cams/BC S&R/SuperTech +1&2 valves/Fuji header/3" exhaust/Calum real time/N60 short ram with JWT POP/Gspec pully set/Fidanza fly/Gspec stage 3 clutch/B&M SS/Tien basics...
93' b13 SE-R: Miss shifted into 2nd after 15 minutes of driving...New engine now
95' 240sx SE: AEM intake with POP charger/ cat-back
www.rapidcustoms.com
Dick is offline   Reply With Quote
Old 06-11-2006, 02:00 PM   #12 (permalink)
Master Cunnilingust
Trader Rating: 37 (100%)
Unless you have an old ass DE maf that reads correctly but is less than perfect and causes your car to have the infamous sh*tty "miss" around 2K-3K rpm. I thought this miss might go away with the VE, but it was still there, and the only things shared between DE and VE were distributor, temp sensors, maf and ECU.
I got my VE MAF from Miko with the engine, he charged me about the same as what someone might ask for any other maf including a plain old DE maf, and it's my understanding that the VE maf is the reason my car runs perfect now. I'm sure the Calum ECU helps as well but maybe didn't solve the sketchy rpms.
- Rob
