Old 03-02-2005, 04:45 AM   #1 (permalink)
SR16VE ECU on SR20VE
Just enquiry
anyone try this before ?
SR16VE ECU on SR20VE with SR16VE cam
any issue ?
will it much better than SR20VE ECU ?
since the SR16VE ECU is programmed to rev cut 8200 compared to 7200 on 20VE
and as far i know 16VE share same injector , MAF so on
just the cam and the cc different
Thank
cmng is offline   Reply With Quote
Old 03-02-2005, 04:57 AM   #2 (permalink)
EECS Nerd.
I know theres a guy in Great Britain that put one on his p11 primera.
Using sr16ve versus sr20ve cams shouldn't matter though. Doesn't serban use sr16ve cams with a JWT (or maybe DE?) ECU (set for sr20ve).
hm..
Old 03-02-2005, 05:14 AM   #3 (permalink)
Emm
the issue is SR16VE ECU on SR20VE
everything is same even cam is 16VE cam
just the displacement is different
Old 03-02-2005, 05:29 AM   #4 (permalink)
DVNO, 4 capital letters.
I have done it with zero issues. I highly recommend it over the stock 20ve ECU. Rev cut is around 7800 I believe. Injectors, and MAF are indeed the same.
Old 03-02-2005, 05:54 AM   #5 (permalink)
EECS Nerd.
Thats what I said.
A guy in UK uses 16 ECU on his 20 =]
Old 03-02-2005, 05:58 AM   #6 (permalink)
ok thank..
i think rev cut is 8200..
Old 03-02-2005, 05:50 PM   #7 (permalink)
From the land of Imports
That's interesting, cause there is a girl over here in NZ that has tried the 16ve ecu in a 20ve and it ran REALLY lean.
16ve ecu runs different ignition advance and the fuel maps are different compared to a 20ve ecu.
16ve rev limit is 8200, compared to the low 7200 of the 20ve ecu.
I've also hear of someone else who ran the 16ve ecu on a virtually stock 20ve and had a few issues with big flat spots in rev range....but as mentioned about, others have no issues....could be the different fuel?
nismotoy is offline   Reply With Quote
Old 03-02-2005, 06:08 PM   #8 (permalink)
ClamSlut
Calum's Avatar
Approved vendor
Trader Rating: 24 (100%)
The mafs are not always the same. The 16VE and 20VE roms I've got have different VQ maps. Compare for yourself.
calum@calumsult.com
Old 03-02-2005, 10:49 PM   #9 (permalink)
emm
the issue is some people using on 20VE retaining stock 20VE cam
my case is i use 16VE cam .
Old 03-02-2005, 10:54 PM   #10 (permalink)
Calum, I have checked both my MAF, and a MAF from a sr16ve front clip where I got the ECU from and the part number was the same. What adr file are you using to compare the two? I know the one from the ztechz forum that you put together had some inaccuracies.
Old 03-03-2005, 01:44 AM   #11 (permalink)
N15 Pulsar 20v
16 VZR ecu on SR20 ve
Originally Posted by cmng
emm
Im the guy that uses a VZR ecu on 20VE motor. Use to have the problem that the motor ran very lean but have learned in the meantime that we were running the old DE Maf. Since changed to a VE maf and boy,what a difference. I now have bought another VZR ecu for anyone who wants to upgrade
kiwi-japie is offline   Reply With Quote
Old 03-03-2005, 02:07 AM   #12 (permalink)
Hmm how much are you looking for?
Old 03-03-2005, 02:08 AM   #13 (permalink)
Oh mean you running DE maf it run lean
but runing VE maf everything is great..
great .. thank for the info
Old 03-03-2005, 05:47 PM   #14 (permalink)
Pulsar VZ-R N1
Originally Posted by kiwi-japie
Im the guy that uses a VZR ecu on 20VE motor. rade
You also had bought that computer from South Africa to try?...that was a big failure then?
EVLDAN
evldan is offline   Reply With Quote
Old 03-03-2005, 06:14 PM   #15 (permalink)
retired
If its the same address file for both roms it would be pulling the vq from the same address in the rom, vq map values are off but iirc not by much, and since its pulling from the same place it cant be that one map is shifted. Then again there are other nissan roms with 2 vq maps. Who knows what nissan is doing.
NOT SR20 POWERED
needs.
Old 03-03-2005, 08:01 PM   #16 (permalink)
So your now using the sr16ve ecu and maf and not having any issues? have you redyno'd the car since? as I seem to remember you where down on power by a fair amount....?
have you compared the sr20ve ecu to the sr16ve ecu now your running the correct maf?
Old 03-03-2005, 08:34 PM   #17 (permalink)
ClamSlut
Calum's Avatar
Approved vendor
That one. The VQ table is correct. We need to figure out what exact engine those ecus go with, I think there are more variations of the VE floating around than people think.
Old 03-03-2005, 10:18 PM   #18 (permalink)
it will run lean.. cause i got a friend running his car with this ecu and when you rev hard it will be very lean...
BTW, the ecu 16 ecu will cut at 8k, not 8.2, check using consult and data logger..
weikee is offline   Reply With Quote
Old 03-04-2005, 12:48 AM   #19 (permalink)
N15 Pulsar 20v
The problem with the piggyback was that we couldnt get the trigger pattern. That company are now building a piggyback for Nissan specific. They have learned from their USA agents that there are a huge demand for something like that. The piggyback they sold me are used with huge succsess but mostly by Volkswagen users and that uses a different trigger pattern that we are using on the Nissans.
Old 03-04-2005, 12:49 AM   #20 (permalink)
N15 Pulsar 20v
$500 NZD
