Old 03-03-2005, 12:51 PM   #1 (permalink)
VVL Nut
Popping on acceleration
At one point last night when driving home, under normal acceleration, the exhaust would pop quite a bit also had a lack of power. Then after a while it would be fine. Did it somewhat this morning as well.
Not sure if this is related to all this but, this past Monday, the car wouldnt start. Had to hold the gas to the floor and start it. Started up after a while. Then it drove fine until last night.
I dont know if the fuel pump is on its way out or bad gas or what.
98 200SX SE
SR20VE
200SXSE is offline   Reply With Quote
Old 03-03-2005, 01:03 PM   #2 (permalink)
NeoVVL Egg
Yeah, Sounds like a possible fuel pump....when was the last time you changed your fuel filter??
John
-John-
1992 Nx2000
Sr16ve, Hotshot CAI, VE Exh. Manifold w/hotshot downpipe, 2.5" Megan Racing cat-back, msd window switch, nismo fpr, eibach pro-kits and kyb gr2's, b14 se-r Wheels, Exxd Ecu.
NismoNx2000 is offline   Reply With Quote
Old 03-03-2005, 01:06 PM   #3 (permalink)
VVL Nut
25k ago.
Old 03-03-2005, 04:13 PM   #4 (permalink)
Tired Greasemonkey
Originally Posted by 200SXSE
25k ago.
do them every year.
Old 03-04-2005, 02:27 AM   #5 (permalink)
Egger
make sure your solinoids aren't activating at low RPMs. sounds exactly like a prob i had.
NXFuer is offline   Reply With Quote
Old 05-04-2005, 12:43 PM   #6 (permalink)
VVL Nut
I finally found the reoccuring gremlin that caused all this. I guess I was dumb for using the supplied scotch lock/ wire tap ..whatever its called for the msd switch into the rpm wire. Well a couple days ago I took it apart and the wire was corroded and hanging by a couple threads that broke easily when I bent them. After fixing that the proper way, no popping, no wierd starts, which now is obvious why I had all that. Hope this helps anyone having those sorts of problems.
Old 05-04-2005, 12:51 PM   #7 (permalink)
70/30 Racing
Rockwood's Avatar
another possible cause (though obviously not your problem) is a dead/clogged cat.
Steve Rockwood
92 G20 - PTD #73
Old 05-04-2005, 02:34 PM   #8 (permalink)
agent camel toe
anyone have some fireballs come out their exh
nyce1s.com
R.I.P. RESPECT SR.
93 p10 jdm de--for sale
96 b14 det--for sale
89 formula--sold
next up is a minivan
