Old 03-06-2005, 08:50 AM   #1 (permalink)
SR20VE powered P11 GT
SR20VE identification.
If the NEOVVL lable has been removed from the cam cover, what other way are there of telling if the engine is a VE or a DE.
(Pics with the explination would be a help.)
Thanks, Al.
Old 03-06-2005, 10:00 AM   #2 (permalink)
eric96ser's Avatar
Trader Rating: 16 (100%)
Look for the cam solenoids behind the distributor.
1991 Sentra SE-R
The community is here.
Old 03-07-2005, 12:32 AM   #3 (permalink)
seen the light
Pop the oil cap on the rocker cover and look at the camshaft...VVL has three lobes per side per cylinder, two will be easily visable visible, one small then middle one big then another small lobe to the other side of the big lobe
HP11 VE - SOLD
BCNR33 GT-R - SOLD
HP12 20V family sedan.
S14 all motor track coupe in the pipeline
madandy is offline   Reply With Quote
Old 03-07-2005, 11:13 AM   #4 (permalink)
VVL Nut
The casting number on the VE block is 53c and the DE is 53j, I believe.
98 200SX SE
SR20VE
200SXSE is offline   Reply With Quote
Old 03-07-2005, 11:39 AM   #5 (permalink)
They're just cones!
IIRC (since I've never seen one in persone) the oil filter is on the back, like a 2000+ roller motors, and there is no oil catch can on the front of the motor. I still think the solenoids would be the easiest to spot.
Matt
Boosted as of 11/15/05
Driven97 is offline   Reply With Quote
Old 03-08-2005, 08:05 AM   #6 (permalink)
Can someone post up a clear pic of the cam solenoids. In all the pics I've got the HT leads are in the way.
Old 03-08-2005, 08:32 AM   #7 (permalink)
retired
Gold things. The valve cover is also alittle taller and more square on the inside.
NOT SR20 POWERED
needs.
Old 03-08-2005, 09:20 AM   #8 (permalink)
Thanks. Thats exacly what I'm after...
