Old 03-10-2005, 03:03 PM   #1 (permalink)
Trader Rating: 15 (100%)
1.6 to 2.0 vvl
i'm trying to get all parts to put 2.0 vvl in my 200sx ....it starts out as a 1.6 so i know i need a lot of parts...i just want to know if my list is right and if anyone can add to it that would be great...i need all the help i can get
All Brackets and Motor Mounts
Koyo Radiator
Clutch
JWT Pop Charger and VE MAF
SE-R 5 Speed LSD Transmission
Axles
Clutch Cable
SE-R Gauge Cluster
SE-R Starter JGY
Flywheel
ECU
SR20VE Engine
SE-R Alternator
SR20 Bolts and Hardware
Wiring Harness
Heater Hoses
Power Steering Pump and lines
Summit Solenoids
Thermostat
Seals
FoolishWayz33 is offline   Reply With Quote
Old 03-10-2005, 04:02 PM   #2 (permalink)
Baby Blue VVL
Brakes to fit the axles
VVL?
IX MR?
A race????
Old 03-10-2005, 09:36 PM   #3 (permalink)
hmmmm. actually the brakes on your 1.6 will accept the sr axles. i did the sr swap into my 1.6. 2.0 throttle cable and also lower se-r engine crossmember with rear mount will be needed. good luck mang
NismoB14 is offline   Reply With Quote
Old 03-10-2005, 11:00 PM   #4 (permalink)
i have all mounts but....i thought i could use my crossmember from the 1.6 to the 2.0 i thought they were the same.....its manual already and im keeping it that way
Old 03-10-2005, 11:01 PM   #5 (permalink)
well, yeah you can, but with mine, the rear mount wouldnt come off so i just had to take it off the se-r . good luck my brotha
Old 03-10-2005, 11:20 PM   #6 (permalink)
anyone else see anything they can help me with???? i need as much help as i can get....not trying to buy anything thats not needed
Old 03-10-2005, 11:42 PM   #7 (permalink)
yea and i also want to know if i get a full front clip with vvl ecu and wire harness and use that in my 200sx i know the gauges wont work in my car but will it activate the cam switch over point or will i still need to use summit solenoids???
Old 03-10-2005, 11:47 PM   #8 (permalink)
oh and i know i need distributor from a 2.0.....do i need cap rotor wires(everything) or just cap and rotor??
Old 03-11-2005, 02:03 AM   #9 (permalink)
im doing this swap next week but instead of a b14 it is on a b13
i'll let you know if i foind anythinf else out
stealth_b13 is offline   Reply With Quote
Old 03-11-2005, 01:23 PM   #10 (permalink)
alright
Old 03-12-2005, 03:06 PM   #11 (permalink)
And who in here is running nos on the vvl....if so how much of a shot and what kind of setup do you have??
Old 03-12-2005, 03:48 PM   #12 (permalink)
Nismo1997's Avatar
Trader Rating: 154 (100%)
I was going to do a DET into my 1.6 but you have to convert from OBDII-OBD1.
You also have to change the inside harness
2000 G20
1992 Sentra
2007 Suzuki GSXR 750
Nismo1997 is offline   Reply With Quote
Old 03-12-2005, 10:22 PM   #13 (permalink)
well i have a 99 harness and ecu from a 99 se-l
Old 03-12-2005, 11:28 PM   #14 (permalink)
Nismo1997's Avatar
Do you have the 99 still, you will need more then just the engine harness
Old 03-13-2005, 05:52 PM   #15 (permalink)
what else will i need??
Old 03-13-2005, 05:59 PM   #16 (permalink)
Nismo1997's Avatar
You will need the inside harness behind the harness and cluster, 95-99 Distribator
Old 03-13-2005, 05:59 PM   #17 (permalink)
f*ck auto*****s
a/c compressor and MAF. good luck and please break into the low 13's people need to be faster with this engine I got a bet going...
join
www. sr20 - forum .com
(no spaces)
Jaralaccs is offline   Reply With Quote
Old 03-13-2005, 06:00 PM   #18 (permalink)
Nismo1997's Avatar
I wouldnt put A/C on this engine. MAF use Sr20DE
Old 03-13-2005, 06:02 PM   #19 (permalink)
yeah i got the cluster and maf......not running with the a/c
Old 03-13-2005, 06:03 PM   #20 (permalink)
oh and i know i need distributor from a 2.0.....do i need cap rotor wires(everything) or just cap and rotor?? ( i'm still trying to figure out exactly what i need)
