Old 03-12-2005, 08:39 AM   #1 (permalink)
Want to Borrow JWT VE ECU
VE Family:
I'm having a couple of issues with my VE. To eliminate the ECU as a source, I'd very much like to swap in a known good ECU -- JWT programmed for a B13 with VE injectors and DE MAF. I'm located near Frederick, Maryland. If you have a JWT ECU programmed for VE injectors and DE MAF, and would be willing to do a swap test with me, please post here or send me a PM. I'm willing to drive to southern PA, northern Virgina, DC, Baltimore, etc., to do this swap.
Thanks very much -- I know that this would be a minor PITA, and I appreciate your consideration.
Bill Conner
PS-> The thread found here describes the problems that I'm having.
http://www.sr20forum.com/sr20ve-sr16ve/107948-ve-dyno-results-reveal-troubles-2-a.html
Old 03-18-2005, 11:56 AM   #2 (permalink)
agent camel toe
sounds like a lose connection at that high rpm range..after reading this article i would go over the pos. conection and the neg.maybe theirs a bad solenoid in the rpm triggers..on my gsr i wired the vtec to my tach..so basically when the shift light came on the v tec would pop..thus allowing me to control and set my v tec to a certain rpm depending on the driving.try going over the installation on the mss
nyce1s.com
R.I.P. RESPECT SR.
93 p10 jdm de--for sale
96 b14 det--for sale
89 formula--sold
next up is a minivan
Old 03-18-2005, 05:18 PM   #3 (permalink)
tbags-
Thanks -- I've got some ideas to pursue this weekend. I hope to get this sorted out before the convention.
Bill
Old 03-18-2005, 05:28 PM   #4 (permalink)
agent camel toe
well anything to help..if so ill give u the number of my tech. who could probably help u with some stuff..let me know
