Old 03-23-2005, 06:06 AM   #1 (permalink)
4 throttle on VE
Just wondering
Given a option which one your prefer
4 throttle on VE ( 42mm or 38 mm inlet each throttle )
Complete N1 Intake manifold ?
cmng is offline   Reply With Quote
Old 03-23-2005, 10:08 AM   #2 (permalink)
Trader Rating: 102 (100%)
I'd like to see a 4 tb setup on a VE.
Old 03-23-2005, 10:36 AM   #3 (permalink)
im a humble cyclist
TuNeDseR031's Avatar
I would agree myself , 4 throttle body look sink!
Just simply a Nobody .
TuNeDseR031 is offline   Reply With Quote
Old 03-23-2005, 10:46 AM   #4 (permalink)
1.6 3/25/06 VE 7/11/06
Trader Rating: 25 (100%)
have you seen the one on sr20store.com? that is sick, wish i had the money for that
bj200sx is offline   Reply With Quote
Old 03-23-2005, 10:50 AM   #5 (permalink)
Old 03-23-2005, 11:50 AM   #6 (permalink)
im a humble cyclist
That could and would never be a daily driven, when it goes into a car..... But Im def still dreaming on something like that ! Good sh*t B i t c h e s!
Old 03-23-2005, 01:42 PM   #7 (permalink)
SE-R GREEK
Originally Posted by cmng
Just wondering
Isn't 38mm a bit on the low side?
Chris
Old 03-23-2005, 01:43 PM   #8 (permalink)
Trader Rating: 15 (94%)
yeah it can, just have to convert to MAP, and use some sort of standalone management, Madd money involved but it can be done
Project Shift_Rebirth
Nyc Sr20PowerD is offline   Reply With Quote
Old 03-23-2005, 02:25 PM   #9 (permalink)
38m is the butterfly size
emm not neccesary going to map
you still can use back MAF if make a plenum like RNN14
Old 03-23-2005, 02:53 PM   #10 (permalink)
wannabie ser
what about the gtir ivtb will that work on a ve
Check out Lostpower
save a tree burn a bush!!!
hector200sx is offline   Reply With Quote
Old 03-23-2005, 04:52 PM   #11 (permalink)
Pulsar 20V
let forget about 4 TB setup, I gave up mine and go for custom make intake with 75mm TB. the 4tb one idle like crap, doesnt gain me much power at top end, throttle become too sensitive and make me hard to drive. it might be good for race car, but I dont think ve engine like it, I will see how my new custom make intake output on dyno next week (compare to 4tb one).
PennyFan is offline   Reply With Quote
Old 03-23-2005, 07:50 PM   #12 (permalink)
yeah anything can me made with madd money, you don't even wanna know what i'm gonna do once i have the chance
Old 03-24-2005, 12:35 AM   #13 (permalink)
KIWI VE
I think Mr PennyFan also had fitment issues in terms of bigger trumpets. For the RWD boys no issues but for us the firewall becomes an issue.
Franklin cams this... stock valve springs that...
I don't care I have a GTR
NAracer is offline   Reply With Quote
Old 03-24-2005, 03:38 AM   #14 (permalink)
ITB need proper setup..
i was told it not like just bolt on on the engine
you need to test each of the ITB measurement correctly and each of the ITB flow correctly
Was told not many tuner are capable to tune 4 throttle via MAF
Old 03-24-2005, 04:25 AM   #15 (permalink)
70/30 Racing
Rockwood's Avatar
Chris
keep in mind that's for each cylinder. it would be like running a 152mm single TB.
Steve Rockwood
92 G20 - PTD #73
Old 03-24-2005, 04:40 AM   #16 (permalink)
SE-R GREEK
I know guys. It is just that whenever I asked anyone (Jenvey, PM) about 42mm TBs for SR20s they "suggested 45mm.
Chris
Old 03-24-2005, 05:06 AM   #17 (permalink)
Always Different !
OK, it's not on the road, but it's running 51mm at the body opeing and tapers to 48mm at the manifold face, not the head face. Butterfly is like 50mm. 4 of them. The RamPipe mouth is like 58mm. JENVEY specifications all the way.
Tuned length is more important for a street machine than bore size, 38 to 40mm is fine enough, with the 86mm bore x stroke the bore size of the throttle is not so critical at sub 8,000rpm.
BIGtoe
Beware of, "Repetitious Mupitism"
bigtoe is offline   Reply With Quote
Old 03-24-2005, 05:51 AM   #18 (permalink)
GT2835R
Yea, but its not a VE
Rey Uy
99 SE-Limited
Old 03-24-2005, 10:09 AM   #19 (permalink)
ohh yeah the one on sr20store.com isn't but what about the pic above? isn't that one? i got confused over the two pics
Old 03-27-2005, 05:07 AM   #20 (permalink)
The VE has a low port head so I'm also under the impression that a GTI-R quad trhottle manifold will fit it perfectly....??
Sabre 200 Gxi is offline   Reply With Quote
