Old 06-21-2005, 10:02 PM   #1 (permalink)
idles funny when cold...
in the morning when i turn my car on my it idles funny for like 5secs unless i feather the gas a lil and then it idles fine.. what do u guys think it is and how can i fix it..
p.s
and its not only in the morning is when the engine cools down too....
pitos_sr20 is offline   Reply With Quote
Old 06-21-2005, 10:46 PM   #2 (permalink)
agent camel toe
what ecu?inj.?maf?could be running rich
nyce1s.com
R.I.P. RESPECT SR.
93 p10 jdm de--for sale
96 b14 det--for sale
89 formula--sold
next up is a minivan
Old 06-22-2005, 10:52 AM   #3 (permalink)
stock de ecu, de maf, and ve inj... im getting my jwt ecu this friday... u think that will make a diff?? and i have a fuel pump to put on but im not sure if its ok to put it on now or after i put the ecu in...
Old 06-22-2005, 01:26 PM   #4 (permalink)
No. 17 is your problem, you should clean it.
Did a write up on NissanMexico.org in spanish, you might want to check it.
Nissan Primera 2001 Turbo - Daily
Nissan 240SX RPS13 Turbo - Track drifter
Subaru Legacy H6 2005 AWD - Boxer AWD madness
CarloSR is offline   Reply With Quote
Old 06-22-2005, 02:17 PM   #5 (permalink)
eric96ser's Avatar
Trader Rating: 16 (100%)
VE's don't have that part.
1991 Sentra SE-R
The community is here.
Old 06-22-2005, 02:29 PM   #6 (permalink)
Trader Rating: 102 (100%)
How does it idle funny? A VE will idle high on a cold start until it warms up. But running VE injectors with a DE ECU could be the culprit too.
Old 06-22-2005, 03:25 PM   #7 (permalink)
agent camel toe
its ur ecu..ur dumping 2 much fuel..ur ecu is set to 259 and u have 319 injectors pumping..u need a reprogrammed ecu.set the timing to 22" now and dont beat on her.when ur jwt comes in set the car to timing mode and then set the timing to 15"..done deal..hey i've seen it work on other cars.that pic looks like a de to me
Old 06-22-2005, 03:27 PM   #8 (permalink)
Didn't saw that was on the VE forum or that he had a VE....sorry.
Old 06-22-2005, 04:14 PM   #9 (permalink)
agent camel toe
its all g,nice of u to try pics
Old 06-22-2005, 10:02 PM   #10 (permalink)
well it looks for a idle when it starts... should i wait till i get the ecu to put the new fuel pump??
Old 06-22-2005, 10:06 PM   #11 (permalink)
agent camel toe
no put the fuel pump in
Old 06-22-2005, 10:09 PM   #12 (permalink)
aight thanx... ill post it up if it stops idleling funny or not...
Old 06-23-2005, 12:31 AM   #13 (permalink)
owned by SE-Rs!
My VE is having similar issues with a JWT ECU, VE injectors, VE MAF. I start my car in the mornings and the car dies. It tries to stay alive, but the RPMs bounce around everywhere around 700 RPM, but eventually they dip too low and the car dies. What could be my problem? My throttle body is perfectly clean...any ideas?
93 Sentra SE-R
Work in Progress
Old 06-23-2005, 03:24 AM   #14 (permalink)
agent camel toe
what vac r u reading at idle?
