Originally Posted by lalito
fruk, thunderstorm coming big time.
I checked the
a) fuse
b) fuel lines correct
c) ground wires on intake many
I think I hear the fuel pump come on that's the wierd part.
I'll get back to you guys after this rain passes.....
yes a killer storm is coming i hear it outside my window.
when u removed the lines to check them, did fuel spurt out some?? if it didnt then fuel isnt getting there. if the fuel is getting there, then the injectors arent firing.
Remove distributor from engine, but leave the harness plugged in.
Turn the key to the ON position.
rotate the distributor teeth, u should hear each injector fire (tick, tick, tick, tick).
This will soak the spark plugs, remove the spark plugs and check to see if they are soaked.
If you dont hear the tick tick, your distributor isnt talking to the ecu.
If you hear the tick tick, and dont have fuel on sparkplugs, ALL your injectors have somehow became clogged.
