My exhaust solenoid?(the one to the right) is leaking oil every once in a while. After driving it several miles ill pop the hood and ill see a litle pudle of oil inside the conector. Is this because the cams arent hooked up? or just the solenoid is going bad? Also for you using greddy mss, if i only have my rpm hooked up to it, do i leave the x1000kpa at the default 999 or do i put it at 0?
