i have a used set and i put a set of new ones in chris200t/amber's NX. thing runs great. mossy has them new. btw dont forget to grind the oil squirter clearance.
i wondering
putting SR16VE piston will yield 14 to 1
but do putting 2 gasket will yield it down to 13 ?
i no idea one OEM gasket thickness
but since metal gasket is available maybe 2 piece of it can help ?
How much do you have to grind off the oil squirter clearance
just as much as the 2.0 pistons you remove. use the 2.0 piston as a guide. can be done easily with a dremel. if you are interested in the ones i have i will do it for you before i send it.
