B15 + SR20VE (Many Pictures Included) - Page 4 - SR20 Forum
Old 07-19-2005, 04:13 AM   #61 (permalink)
looking awesome there, love those front brakes.
And come on guys please stop the " how much did it cost??" questions, everyone knows we never know how much or we would never do it.
My wife always says whatever figure i tell her she would triple it and it would be getting close.
1997, n15 pulsar (autech) sr16ve powered (under construction)
1998 p11 primera cvt family wagon, sr20ve powered
1990 B13 sunny gts with sr20ve on engine stand to go in it
shortz is offline   Reply With Quote
Old 07-19-2005, 04:23 AM   #62 (permalink)
GT2835R
That thing is sick. Good to see some race prepped sentras.
Rey Uy
99 SE-Limited
Old 07-19-2005, 05:09 AM   #63 (permalink)
Devil's Advocate
Whats the curb weight?
04 G35s Sport/6MT/NISMO Aero/Z-Tube/K&N Filter/Plenum Spacer/NISMO susp/TR MT-1 wheels/Brembo's/Clear Corners/Stillen Sways
02 Vibrant Blue SpecV/NISMO CAI/ES MMI
92 Classic/U12/GT2860RS/Divorced o2/CXR FMIC/Calum R/T ECU/Zt-2/Z32 MAF/S15 inj/Apexi TT/Greddy Profec B/3" Turbo Back/Hyperco Gen II's/KYB AGX's/ES Mounts/Cluthnet Type 1 P/P-6 Puck Disc/Jun Flywheel/NX2K Brakes/Silver Kosei K-1's
Hybrid_DET is offline   Reply With Quote
Old 07-19-2005, 07:49 AM   #64 (permalink)
SE-R Driver
Dotto! Nice car.
When you find an adaptor plate for the oil cooler, please let me know.
STU Yellow Sentra SE-R, So. Fla.
VVL Powered!!! Road Racer
Synergy Florida Insoles LLC.
772.336.6452
www.synergyinsoles.com
Andy R. is offline   Reply With Quote
Old 07-19-2005, 07:09 PM   #65 (permalink)
Guanaco Tuner
Feedback Score: 11 reviews
Glad you finally got it done, looks pretty.
Old 07-19-2005, 07:25 PM   #66 (permalink)
SE-R Pheen
yeah she's a cutey
IIKI B-13 is offline   Reply With Quote
Old 07-20-2005, 12:33 AM   #67 (permalink)
Originally Posted by Salvisol82
Loving that car man. Real clean. Hey since you have that qr tranny maybe you can upgrade that ve with some boost. . BigJohn is making some nice numbers with just a t25 kit.
Probably won't put boost on it. For one, I don't know anything about turbos. Two, it wouldn't be allowed in USTCC.
Cup Driver #21 is offline   Reply With Quote
Old 07-20-2005, 12:38 AM   #68 (permalink)
Originally Posted by unlucky
John....
Did you use the QR starter? If you can use the QR starter... then I have flywheels made for this swap. It would eliminate the need to have the collar made with the throwout bearing. We had the flywheel made for the destroked QR, using the SR20 crankshaft.. but it would work perfectly for what you have done.
Also, would a Primera 6spd axle work? This would eliminate the need to have a custom adaptor made for the axle bracket (to the block). Get a Primera 6spd axle.. and bust the boot loose right past the big bearing/bracket assembly. Then, use B15 QR axle the rest of the way. Should work just fine.. we're doing something similar with the VQ35 swapped B15.
Just a few suggestions for those looking to duplicate this.
Travis
Travis,
I used the sr starter. The bell housing mounts the starter in the same place as the regular sr bell housing. Good idea on the passenger side axle though. It will probably work. Just need to source a Primera 6spd axle AND the bracket. Can you get these items?
Old 07-20-2005, 12:47 AM   #69 (permalink)
I haven't weighed it yet.
Old 07-20-2005, 01:07 AM   #70 (permalink)
Dyno Chart for the B15 VE located here:
http://www.sr20forum.com/sr20ve-sr16ve/123384-spec-ve-dyno-chart.html
Old 07-27-2005, 06:08 PM   #71 (permalink)
Originally Posted by Rockwood
btw, might want to move the battery kill switch somewhere the emergency workers can reach it too, in case you get knocked out or something. mine will go next to the driver's mirror.
I'd look for a better stronger way to secure the battery. After John Lindseys accident, I build overkill battery mounts.
John had the exact same battery box and I assume mounting system that came with the box as you. That broke spectacularty and let the battery flail around the inside of the car.
choaderboy2 is offline   Reply With Quote
Old 07-27-2005, 07:03 PM   #72 (permalink)
70/30 Racing
Rockwood's Avatar
nothing quite like a 30lb ball and chain to make my day...
MotoIQ Project G20:
