I have read that a realy is needed to up the amp. to the soleniod from the msd rpm swithch box. I read to just use a normal nissan 4 prong soleniod.
my question is, do i need this in order for the cams to change? and if so, how to wire the realy????
Ok, so heres how i think it needs to be done.?? is this right?
"im fly like Stevie Wonder ribbon, girls got my name on em and the boy still livin"
White Wire to #30 (cam activation wire)
Yellow Wire to #85 (from MSD trigger)
Black Wire to #87 (12V Power)
Red Wire to #86 (Switched Power)
#30, #85, #87, #86 what are these? are these the pin #'s on the relay or somting?
also, the 12v power, obviously battery right. switched power is the ignition correct?? sorry if i sound stupid, im just tryin to get everything i need to know, thanks alot guys
the numbers are the identification numbers on the relay itself, 12v is battery , switched is ignition.
