Originally Posted by pachadwick
It is interesting to speculate, I know that people in California have done this. How much difference would it make? You have a yard of inlet track before the TB and 14" of manifold after the TB, the TB is only 3'' long just how much heat does that impart to the charge? There are downsides, I'm guessing that your throttle warm-up adjustment is on the TB, if you disconnect the hoses then your warm-up cycle could last 30 minutes instead of 15.....you could have a warm-up (choke-out) idle of 1200 rpm for upto 25minutes instead of 10. I don't know really.
Perhaps someone else can give feedback here.
Thanks Paul
Well, I'm in NZ, it gets pretty cold down here in winter, but not really freezing temps in the North Island where I am....I have the spacers on my VE, and have re-routed the coolant lines. I don't have any cold idle issues - only sits at ~1100rpm for a minute or too then down to 700-800rpm
Noticeable difference in touch on the plenum & t/b...I have a stainless strut brace that i can't touch after a run...and that's just from the engine bay temps, I can rest my hand comfortably on the plenum (couldn't before the spacers where installed) I can only assume that's got to be a good thing
sorry, no dyno comparison though, bit expensive!
Cheers, nismotoy.
