Spec VE Dyno Chart - SR20 Forum
Old 07-20-2005, 07:14 PM   #1 (permalink)
Spec VE Dyno Chart
Here is a dyno sheet of my first dyno session. I just did some tuning with the little mods that I had. Just wanted to make sure that the engine is strong and that all my vvl switch points, fuel pressure, and AF ratio was at a safe and reasonable setting. As you can see run 9 is my best run. Don't mind the torque. There was a blip in the sensor. I figure torque was ~150-152 ft-lbs.
--John Almazan
Cup Driver #21 is offline   Reply With Quote
Old 07-20-2005, 07:40 PM   #2 (permalink)
Turbo Grocery Getter
Feedback Score: 17 reviews
good numbers and nice looking curve. should be pretty mean on the track. sr16 cams???
Modding for MPG now.
sr20sleeper is offline   Reply With Quote
Old 07-20-2005, 07:47 PM   #3 (permalink)
I'm pretty positive he's still using the SR20VE cams
93.5 G20 VE 3 inch exhaust,JWT ECU,5k pill(one trigger) no weight reduction LSD SE-R Transmission 14.805@95.041
Will be turbo'd with Aquamist soon to come
SR20loper is offline   Reply With Quote
Old 07-20-2005, 07:52 PM   #4 (permalink)
No, I don't have sr16 cams...yet.
Old 07-20-2005, 08:27 PM   #5 (permalink)
agent camel toe
Feedback Score: 22 reviews
Fujitsubo Exhaust Manifold
3 inch intake piping
Dirty K&N Filter
94 SE-R wiring Harness (Only B15 harness are the tail lights)
JWT tuned ECU for SR20VE, 91 Octane, DE TB/MAF
3 Inch Exhaust with Dynomax Bullet Muffler (if you call it that)
so its the basic set-up..intake header exh.its amazine what the ve's capabilities r..
nyce1s.com
R.I.P. RESPECT SR.
96 b14 det--under the knife
2002 quest gxe--pimp wagon
Old 07-20-2005, 08:36 PM   #6 (permalink)
EECS Nerd.
Feedback Score: 3 reviews
If Maui isn't done with his car this Thursday, I think we're (well, me) gonna head up to Sac Sunday
Woo! Geekout.
Old 07-20-2005, 08:37 PM   #7 (permalink)
Professor Dingbat
Feedback Score: 14 reviews
Nice numbers
Arent you concerned that's a little lean towards the end?
Old 07-20-2005, 08:39 PM   #8 (permalink)
agent camel toe
true i thought jwt's run rich
Old 07-20-2005, 08:54 PM   #9 (permalink)
Originally Posted by FastNX
Nice numbers
Correct me if I'm wrong but i'm pretty much lifting towards the end, I would run lean for a quick second correct?
Old 07-20-2005, 09:29 PM   #10 (permalink)
Feedback Score: 4 reviews
Your not lifting where its going lean though, otherwise you would see the power drop dramatically.
Old 07-21-2005, 03:33 AM   #11 (permalink)
VVL SE-R
great numbers, very impressive, especially torque
matt20v is offline   Reply With Quote
Old 07-21-2005, 09:06 AM   #12 (permalink)
Feedback Score: 103 reviews
Very solid numbers for the mods you have! You should expect another 10hp with sr16 cams!
Serban
'11 Mazdaspeed 3
Old 07-21-2005, 09:27 AM   #13 (permalink)
It's actually running a little rich up to 5500 RPM and lean above 6500 RPM. I've just starting messing with the Innovate LM-1 on my VE (Fuji, JWT ECU, DE MAF) and seem to be getting a similar pattern. Since it's a little rich at low RPMs and a little lean at high RPMs, you can't fix both problems by adjusting fuel pressure.
Old 07-21-2005, 09:45 AM   #14 (permalink)
DD'ing 160whp N/A 200SX
what do u use to trigger the solenoids and at what rpm or rpms if u use different ones.
Viprdude's 1995 Nissan 200SX SE-R......|.......CarDomain
YouTube videos of my car/exhaust........|........ All Motor Greatness
“It is not the strongest of the species that survive, nor the most intelligent, but the one most responsive to change.”
viprdude is offline   Reply With Quote
Old 07-21-2005, 11:07 AM   #15 (permalink)
Turbo-VVL finally
It looks like maybe 4500-4600 rpm?
chirpin4th is offline   Reply With Quote
Old 07-21-2005, 10:11 PM   #16 (permalink)
fu*k you.
Feedback Score: 16 reviews
Did you change anything between runs? An 8hp difference out of nowhere wouldn't make me trust those results too much.
Sidenote: I have seen the JWT VE fuel map. It is ridiculously rich at low rpm's and takes away a ton of fuel up high. Not exactly something I would want in my car.
Old 07-21-2005, 10:22 PM   #17 (permalink)
He said he did some tuning (Im assuming base timing and FPR adjustment).
Old 07-22-2005, 12:29 AM   #18 (permalink)
I set the FPR to a setting that I didn't thing would hurt the car. Then I just fiddled with switch points for the most part. I moved my switch points in 100 rpm increments. At the 8th-9th run, I found the optimal switch point for the vvl on my motor. Apparently the starting switch points were not all that great.
Old 07-22-2005, 12:41 AM   #19 (permalink)
Why did you do so many runs to find the switch point? All you need to do is three dyno runs. First do one without switching the cams at all. Do the second run with the intake cam switched on really early. Then do a third run with both intake and exhaust cams switched. Overlay the graphs, find the intersection points, and set your switch points accordingly.
Old 07-22-2005, 02:18 AM   #20 (permalink)
fu*k you.
You arent going to pick up hp through the entire graph with different switch points. Seems the dyno isnt too accurate to have a 5% spread on the same day, same time, same car with the same setup. I would also very interested in further fuel management if I were you, whether it be an eman to get that fuel back up top or an ecu done by calum or myself to get your afr's in check, above 14:1 at the tailpipe is not cool. (If that was indeed a tailpipe mounted o2)
