This is the connectors on the drivers side right above the tranny and below the air intake. The DE harness had three connectors, while the GA only had two. I know with the VE you have to splice into this connector, does any one know if the which wire is which or if pollarity even matters ( which i expect it does ). Both have the same color code, black w/ yellow stripe.
I think it connects to this one with red and black wires. because the other connector is only one wire.
I don't have the battery hooked up yet, so if testing + or - is required i guess i'll wait a couple days. Any help would be appreciated.
