Old 08-01-2005, 12:20 PM   #1 (permalink)
needs to be tuned
geeio's Avatar
ve manifold heatshield
dose any one have a stock ve exhaust manifold heat shield they would like to get rid of ? i knoy ou guys dont use the stock manifold and they usualy come with the engine.
looks like its got a bad sun burn.
geeio is offline   Reply With Quote
Old 08-02-2005, 12:52 AM   #2 (permalink)
rex
I have one. I haven't thrown it away yet, though I bet Mr. Miko either has one or will soon have one soon. He's alot closer.
rex is offline   Reply With Quote
Old 08-02-2005, 03:21 AM   #3 (permalink)
the spookman
I do. I would need to find it though. Its in my garage so it wouldnt be too hard.
05 Legacy GT
93 NX2000 w/VE
(\__/)
(O.o )
Old 08-02-2005, 04:16 AM   #4 (permalink)
1.6 3/25/06 VE 7/11/06
Trader Rating: 25 (100%)
does everyone take off there heat shield and keep the stock manifold on or all of you have aftermarket header on?
bj200sx is offline   Reply With Quote
Old 08-02-2005, 11:48 AM   #5 (permalink)
needs to be tuned
geeio's Avatar
im sure most use some sort of aftermarket header. alot use a de one they had on the car from before. one reason they dont use the ve manifold it because a lot of the time no one has the secondaries. i got my engine with the secondairys and they looked to be a litle better than what i had on there before but i dont have a heat shield and the cast iron holds soo much more heat than the old hot shot i had. and is a caca rust color. ill check out miko first then ill check out either of you guys. thanks for the replys.
