I've tried to set my timing at 20-21 degrees, but it seems to always reset back to around 13 degrees once i turn off the car. do i have to reset the ecu? I am running de injectors, de ecu, de maf.
also another wierd problem..
everytime i start my car, it wont hold idle; i have to step on the gas and hold it for a few seconds for it to hold. and when i start it cold, it idles at around 700, then warms up to normal to about 900-1000rpm instead of it idling high, then dropping down to normal from cold start. random
1.6->2.0L question...
i swapped out my 1.6L temp sensor (red one) and replaced it with the se-r one, and it doesnt work. should i buy a new sensor?
thanks
*edit, 700 rpm. my bad
91 sentra E (sr20ve)
94 300zx Twin Turbo
