Old 08-02-2005, 04:25 AM   #1 (permalink)
few questions...
Just got my ve today. so far *** got it home and put the outlaw thermo blockers on it.
My v/c has sh*tty lookin yellow paint pen writing on it from the place that pulled the motor. How do u get this off with out hurting the color of the v/c?
its not a big deal, but someone might want to add that u have to change the passenger side motor mount bracket from the DE to the VE. I have never read about it in anyof the write ups, but i had to do it.
And i read u need to sawp both de temp sensors. oil and water...the water ones are pretty simple to find, there right on the water hardline right below the runner on the intake mainfold, now the oil temp sensor, is this located right next to the oil filter on the ve??? im pretty sure it is.
"im fly like Stevie Wonder ribbon, girls got my name on em and the boy still livin"
1999 GSXR 750
SE-? is offline   Reply With Quote
Old 08-02-2005, 11:13 AM   #2 (permalink)
Trader Rating: 102 (100%)
The mount bracket is different on all JDM DEs too, its a fairly known thing I never changed the sensors, I just had the VE plug spliced into my harness.
Old 08-03-2005, 02:35 AM   #3 (permalink)
aight thanks serban. did u change ur iacv? i have read that you should. so far i *** got my flywheel, clutch on. And i changed my water temps. Im gonna change the oil temp later. anything else recomended that i change?
Old 08-03-2005, 09:01 AM   #4 (permalink)
eric96ser's Avatar
Trader Rating: 16 (100%)
There is no stock oil temp sensor. There is an oil pressure sensor, and that is in the same place as the DE. I used all my stock DE sensors to get things easy and simple. I also kept the VE AAC and IACV, since the DE one doesn't fit, and it would put the idle screw facing down. Just clean the VE part and put it on. To remove the yellow paint, use a little bit of gasoline. Just put enough on a rag, and wipe the yellow paint off.
1991 Sentra SE-R
The community is here.
Old 08-03-2005, 10:09 AM   #5 (permalink)
The VE IACV was left on there, and the wires were spliced for the VE plugs.
Old 08-03-2005, 10:24 AM   #6 (permalink)
post pics of your ride....
lalito is offline   Reply With Quote
Old 08-03-2005, 11:38 AM   #7 (permalink)
i dont have a camera to take pics of the swap
thanks for the help.
Old 08-03-2005, 05:24 PM   #8 (permalink)
SR's are a fad
thats pretty hawt dude. is it me, or do the inner fogs look smaller? and what headlights are those? also, any side shots?
rage is offline   Reply With Quote
Old 08-04-2005, 01:57 AM   #9 (permalink)
inner fogs are smaller i belive. THere stock headlights with black houseings with hid's...
thasts the only side i have.
Old 08-04-2005, 11:31 AM   #10 (permalink)
That sunny front end rocks. If I'd known about it when I got my xenon kit I might have chosen that look instead. It gives the car a much more euro look than mine. I still like mine but its like an apple and and orange...
Old 08-04-2005, 12:27 PM   #11 (permalink)
From Miami to New York
Use Meguiars chrome polish, it should work, I removed most of the lettering off my JDM DE motor with it, it came off with ease. Or some Turtle wax chrome polish.
Miss it
http://www.g20.net/gallery/data/500/medium/425Lip3.JPG
2007 Infiniti M35 Sport
Stuff for sale
MSD red wires $55 shipped, RRSR20 New 50lb Top Feed Inj $250, B13 93' MT ECU $70.00shipped
Domiken is offline   Reply With Quote
Old 08-04-2005, 12:40 PM   #12 (permalink)
agent camel toe
leave it their..it add hp
nyce1s.com
R.I.P. RESPECT SR.
93 p10 jdm de--for sale
96 b14 det--for sale
89 formula--sold
next up is a minivan
Old 08-05-2005, 12:16 AM   #13 (permalink)
well i already added my apc window banners and vtec
stickers, so those will add enough hp ya know...
Ok any last helpful reminders before i put the engine in?
I extended my iacv, and aac wires to reach the new loactions.
I swaped over oil pres, and both water temps.
switched motor mounts etc
tranny, flywheel clutch is all on
es mounts have been pressed in
all i have to do to my knowladge is wire up the msd box to the solenoids
ANything else i should/have to do?
Old 08-05-2005, 01:08 AM   #14 (permalink)
agent camel toe
change the plugs and use ammsoil 10-40
Old 08-05-2005, 01:17 AM   #15 (permalink)
word. i got like month old plugs/wires for my de i will be re using for the time being. Im running redline in the tranny with lucas. and castrol syntec for motor oil... i have alwased usedit......anyone got a spare aac valve???? !!! i need one.
Old 08-05-2005, 01:48 AM   #16 (permalink)
